V70 parts - would you buy these parts?
Has thanked: 2199 times
Been thanked: 1851 times
Thanks for that help. Good to know buying a new one was the only realistic option.
Has thanked: 1609 times
Been thanked: 4065 times
chrafael wrote: 04 Apr 2017, 12:45 The last one I cut open had a nylon screen and the desiccant bag was oil soaked, so heating it won't accomplish anything.
Probably by some cheapskate wondering if 1/2 used engine oil would work as PAG....
Hmmmmmm
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Any decent dryer will work just fine.Any mid grade, just don't buy the cheapest out there, but you don't need to pay Volvo prices for what is essentially a can.
Car will be dead and buried by the time the new one will rust out
Thanks guys, and fair point JRL.
I used the $50 compensation and went for the OE as I do recall the aftermarket one I used last time, while cheap, was a bear to fit and in a tight space that is no fun with big fat fingers and hands!
I think I may have fixed the pump leak. Pulled the end cap that had been dislodged slightly and hence the leak. Cleaned it all off and re-glued back in with JB Weld Plastic waterproof glue. Re-attached to the tank with the rubber seal from the spare tank and filled with water to half way and have left with paper under it for 2 hours and still leak free. I will try to run it this evening to make sure I didn't glue the impeller accidently and if all good cancel the new one from FCP!
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
I just buy the Factory Air or whatever house brand is available for the accumulator/receiver/drier. I've never had any trouble with any of the replacements. I have had trouble with the OEMs but that those problems have been with holes rusting in them after 10 to 12 years of the winter salt bath.
Thanks Lee.
