windshield wiper problem-1994 960
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
sjoyfisher
Year and Model:
Post by sjoyfisher »
Only one windshield wiper works. Do they have individula motors for each wiper?
Sharon Fisher
DanR
Year and Model:
Post by DanR »
No, it is one motor that drives both wiper arms. Most likely it is the nut loosened that holds the arm. At the end of the arm, that cover can be lifted out and underneath is a nut. This holds the arm to the drive stud. You can try tightening it and it may hold, but what has happened is thru continued use with it loose, the hole has ridges to increase the grip to the drive stud, those ridges have been worn away. If it does not hold, then you will have to get a new wiper arm. You might also check the working wiper for a loose nut.
DanR 94 964 332,000 miles (98,000 on the new engine)
CarVolvo
Year and Model:
Post by CarVolvo »
As described the first thing you want to check is the swivel nuts.
But you can also try to determine if the wiper "tansmission" or control arms are loosened.
Take out the glove compartment and look inside up near the dash pad.
Turn on the wipers and see if the two arms are working (they are aluminium in colour). These things are held together with a little metal strap which connect them in tandem.
THE FLEET!:
93 854 GLT 20v non-turbo 435,000 KM +
94 854 20v non-turbo 215,000 KM ..new engine
87 745 B230 non-turbo 250,000 KM (newest edition Jan '07)
86 244 GL B230 non-turbo 460,000+ KM
sjoyfisher
Year and Model:
Thanks guys,
I now have both windshield wipers in working order on my wonderful Volvo. I just happened to accidently acquire this car a year ago and I absolutely love it...
Sharon Fisher
97volvo850driver
Year and Model: 1997 Volvo 850
Post by 97volvo850driver »
Thank you soooo much to all who help on this site. I used this thread to fix my driver's side wiper this morning and was able to safely take my mom to the hospital in the rain...
Having this community for support is wonderful and I just wanted to thank those who responded about the loose wiper nut as well as everyone who take their time to answer and help others.
