'98 S70 Jerky hesitation Topic is solved
misha
Has thanked: 152 times
Been thanked: 402 times
Re: '98 S70 Jerky hesitation
Post by misha »
Fuel pump firstly becomes very noisy before it eventually dies.
If it's quiet i wouldn't worry about it,especially if jumping a fuel pump relay makes problem go away.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
dosbricks
Post by dosbricks »
OK, it doesn't seem unusually noisy. I have a good 103 red relay from my 850 (purchased while throwing parts at another problem). Is it OK to try that 103 in the S70? They seem to be interchangeable according to FCP's parts catalog.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
The 103 relay out of the 850 should be just fine. They should all be the same relay.
misha
Post by misha »
Yes they are.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 292 times
Been thanked: 765 times
Volvo kept using the same fuel pump relay well beyond the 850 - throughout all P80 cars, then on into several of the post-00 vehicles.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
Has thanked: 1497 times
Been thanked: 3810 times
You guys just reminded me I Never cleaned up my relays found at ALbany VolvoFest 2017..
misha wrote: 14 Apr 2017, 10:07 Fuel pump firstly becomes very noisy before it eventually dies.
I've had two P80 fuel pumps fail and they never made any noise. They failed abruptly and without warning. I don't think "becomes very noisy" is by any means typical.
'06 S60 R, 197k
dosbricks
Post by dosbricks »
Thanks erikv11. I'm going to drive the car a few days like cn90 suggested with 15-87 jumpered to watch for any hiccups.
The Bosch pump insert came today and looks genuine. At 229k, do you suggest I go ahead and install it even if this turns out to be the relay? We are going to be making some trips in this car this summer.
229k on a factory pump seems impressive. If the car is going on some trips where failure would be a big hassle then I would do that swap, yes. Make sure the rubber check valve seems to be intact still, when you swap the fuel pump insert.
'06 S60 R, 197k
Been thanked: 466 times
Post by cn90 »
dosbricks,
- Just drive the car a few days with the jumper wire in place.
- The fuel pump: if you only drive locally then I'd leave it alone for now. Just leave the new fuel pump in the trunk just in case.
If you drive long distance, then again carry the fuel pump in the trunk.
It is a toss-up.
- Now, if you decide to replace it (which I think is a good idea anyway), save the old fuel pump in a ZipLoc bag and store it in the trunk for emergency use. New pump can fail too.
- Re fitment: apparently the Bosch 69693 is the real deal, but from my reading of forum, user "stephansvolvo" (search for his posts) had to remove the black casing of the new pump to fit. As you know you need to make sure the polarity is correct. Make note, photos. Also most people say use a new fuel hose (I think it is 8-mm type).
- I replaced the fuel pump cover rubber seal and posted some info, hope you find this DIY helpful:
DIY: 1998 S70 Fuel Pump RUBBER SEAL
viewtopic.php?t=60329
