850 turn signal switch replacement
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 93 times
Been thanked: 146 times
Re: 850 turn signal switch replacement
Post by BEJinFbk »
abscate wrote: 17 Apr 2017, 14:02 you need advanced equipment to test the turn signal switch - see here
Careful study of the waveform reveals why the cruise was inoperative
"Pay no attention to that broken lead behind the curtain!"
Noce scope - Is that a REAL 3-1/2" floppy drive? Sweet! 8)
Has thanked: 292 times
Been thanked: 765 times
BEJinFbk wrote: 17 Apr 2017, 14:20
3-1/2 is such a sweet upgrade, hoping to get to that, mine are all 5-1/4!!
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
BEJinFbk
Post by BEJinFbk »
Hey - All I can do is take a Polaroid of the screen... :(
Been thanked: 472 times
Post by cn90 »
Ha,
In the absence of fancy oscilloscope, a junk yard spare Hazard Switch swap can make the diagnosis quickly.
I am not a "part swapper" but sometimes when you have a spare and the swap is easy, why not?
Erikv, I have not replaced the ignition switch yet (I have a brand-new Volvo OEM switch lying around) but will do soon.
Now that jblackburn updated his thread (see above), it makes sense to me as a few things happen together (although this is < 1% of the time):
- Turn signal not working (hazard switch is working fine)
- Shift Lock inoperative for Automatic shifter
The only way to explain that is "upstream" of the Hazard Switch, which is the Ignition Switch itself.
Also, from my readings of the internet forums, people with exact same problem (only turn signal not working):
- Replaced the Stalk...very often the problem is not solved.
- Replaced the Hazard Switch...problem returned.
- So by deduction and by jblackburn's update ---> I think Ignition Switch is the likely culprit.
I will replace the Ignition Switch soon, but since this problem happens in < 1% of the time, I will need a long period of time such as 6-12 months before I can update the crowd here...LOL.
Has thanked: 1505 times
Been thanked: 3818 times
BEJinFbk wrote: 17 Apr 2017, 17:12 Hey - All I can do is take a Polaroid of the screen... :(
Now I can get rid of my thin tissue paper and charcoal.....
Cn90....I recently took an if switch apart and the contacts can be cleaned. Thread title something like "root failure analysis"
