What kind of oil goes in the pancake? I'm referring to the one that is to the right of the transmission with the drive shafts coming out of it.
Thanks
Transmission pancake oil
malcolmtent
- Year and Model: XC70 2004
- Botbasher
- Year and Model: 98 "R" & 03 T5 V70
- Been thanked: 4 times
Pancake?? I don't think I've ever heard car parts described like that.
You mention drive shafts going into it... Are you talking about the differential?? Or the transmission itself? Both are going to use the same fluid respectivly, but we'd need a bit more information about the vehicle to help you figure out what you actually need.
How about year, model, motor code and trans code?? Something like mine.... 03 V70 B5234T3 AW55-50SN. Can generally be found on plates or stickers on your motor, trans or around the engine bay.
If you can't locate those, then a quick stop into an AutoZone or similar establishment can ID what you have, but before using what they suggest, you should confirm its compatibility with Volvo applications. Not all fluids meet Volvo specs and can damage them!!
Hope this helps!!
K "now I'm hungry" S
Hope this helps!!
Never become a pessimist. A pessimist is correct oftener than an optimist, but an optimist has more fun, and neither can stop the march of events.-Heinlein
We have met the enemy and he is us.-Pogo
If speed kills, do brakes give life??
- mrbrian200
- Has thanked: 7 times
- Been thanked: 84 times
Pancake style slave cylinder (MT hydraulic clutch) He wants to know what type of fluid.
- Has thanked: 1613 times
- Been thanked: 4077 times
I don't think you can get a MT XC70 under the sabre-Maple Leaf DMZ.
It sounds like the differential to me
- Botbasher
He clued is with... Transmission and driveshafts... But that's not nearly enough to figure out what the "pancake" is.
It is really amazing how people translate their perception of motor shapes and functions. I got this all the time in tech service... They'd call well known parts by some oddball name and it took a while to figure out just what they were talking about.
In this case maybe a picture would solve the issue quickly?
KS
KS
JDS60R
- Been thanked: 3 times
I think he means the bevel gear/angle gear. 75W-90 synthetic. Volvo has a low foaming spec for this so other brands will say they do not meet the spec.
Its important to keep up on this fluid due to the bevel gears proximity to the turbo.
Volvo offers an oil for this https://www.fcpeuro.com/products/volvo- ... l-31259380
Retired
JRL
- Year and Model: Several
- Been thanked: 16 times
ANGLE GEAR
Use Volvo fluid only
- Botbasher
I was thinking more of a pic from the OP rather than guesses from the gallery.
WAGs only serve to confuse as evidenced by JRLs answer. See, my WAG would be the strut top. It's the only truly flat, pancake looking thing up there to the right of the transmission, technically the driveshafts go into it at the knuckle and if the lift strut has crapped out, it'll puke a sticky oily substance all over up there.
But again.... Totally a WAG!!
KS
KS
ANgle gear. To the right of the transmission with shafts coming out of it, per OP.
- Botbasher
So it uses the Aunt Jamima 30w Breakfast Oil, right?
That's the first time I've ever heard that one. Pumpkin. Lollipop. Even balloon.
Wasn't thinking viewed from under the car from that description.
K "logical" S
K "logical" S
- 1327 Views
Last post by alschnertz
- 11 Replies
- 1842 Views
Last post by subzerocarfanatic
- 2347 Views
Last post by fitz548
- 1706 Views
Last post by rasense
- 2241 Views
Last post by tryingbe
