Battery low but quasi-stable--why?
- Year and Model: Lots
- Been thanked: 128 times
Hmm some observations contrary to theory: http://www.learnabout-electronics.org/R ... rs_01a.php
rocketman4321
- Year and Model: 850 Turbo 1996
I agree in principle, and that's how I did the negative side test. On the positive side, with turbo and A/T, that involves wedging your hand past the hot radiator, various hoses, and intake manifold to remove the B+ cover and hook up a lead. The resistivity of copper increases about 30% from 20 to 100C, so that's really not a huge issue. (You'll tend to see if there's a problem or not--don't cheer if your drop is 0.199 volts.) The question is whether temperature opens up bad joints or loose connections.
I charged the battery for 6 hours yesterday. It was at 12.77 V right after disconnection and fell to about 12.58 V about 15 min later, which I take to be the surface charge bleeding off. Just sitting in the garage, it lost 0.1 volts in 5 hours, then another 0.05 V overnight, so it's at 12.41 now. That doesn't sound horrible, but it's also not great.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
rocketman4321 wrote: 05 May 2017, 15:28...Is it simply that the 3-year-old "gold" battery won't take a charge?...
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
Thank You.misha wrote: 07 May 2017, 11:34rocketman4321 wrote: 05 May 2017, 15:28...Is it simply that the 3-year-old "gold" battery won't take a charge?...
- misha
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
rocketman4321
Well, it does seem to charge on the charger, which is why I'm puzzled. Of course, the auto parts store only ran a load test.
A bit of an update. First, my meter had a blown fuse that mislead me. I did have the classic glove box problem, draining something over 150 mA. The central locking was another ~40 mA, and everything else was < 20 mA. I doubt that's the root problem here (even for 15 hrs that light is 22 A-hr), but it certainly doesn't help. Fixed with a shim. My daughter drove it around this afternoon, but none of the 3-4 legs were over 10 miles. Was about 12.35 V when she got home and it sat for a few minutes.
- 4487 Views
Last post by jpeter
- 1271 Views
Last post by mrbrian200
- 432 Views
Last post by Pennybags
- 4083 Views
Last post by MathalomuleM31
- 2267 Views
Last post by db130
