turn signal relay location Topic is solved
nb2008s80
Year and Model: 2008 S80 4.4l
Post by nb2008s80 »
Hi.
I have a 2008 s80 4.4l and need to replace the turn signal relay (flasher) but I'll be darned if I can locate where it is. So far nobody has been able to help. I would like the location and part number as well as how many pins, I have seen 3 pin, 4 pin and 5 pin mentioned but not certain. Help is greatly appreciated.
yagger
Year and Model: V60 2016
Has thanked: 6 times
Been thanked: 39 times
Post by yagger »
You can not replace relay for turn indicators. There are not relay for this indicators. Can you explain what happened with your car?
If you mean relay for sound only, this relay in the DIM (dashboard). If you can to do solder work, good luck.
nb2008s80
Post by nb2008s80 »
Thanks very much. This explains why nobody knew where to find it. A great relief.
nb2008s80
Post by nb2008s80 »
Since there is no turn signal relay what can be done to fix hyper flash using leds.
yagger
Post by yagger »
You need to change circuit of CEM a little bit. There are load resistors for check loads your turns lamps. If you know how to do this, good luck. ))
