Where could I buy or rebuild CEM for 07 XC90
- yagger
- Year and Model: V60 2016
- Has thanked: 6 times
- Been thanked: 39 times
What happened with your CEM?
- For example
- ebay cem-h.jpg (526.88 KiB) Viewed 10105 times
Volvo electronic expert
Online Data Transferring Service for Volvo modules
nyc1836
- Year and Model: 2002VOLVO S80 T6
About 6 weeks ago we drove the SUV from Texas to Miami stayed there 2 weeks and came back total about 3000 miles the anti skid service and DSTC came on several times car drove fine the other night my wife was 5 minutes from house started car abs check engine and other lights came on she told me to check.I tried to start car no luck Brake Failure - We diagnosed the car no communication to main computer with OBD even though I plugged in another used computer which started to read codes but wouldn't stat because probably needs programming so we put back old computer started car once and then again same problem no communication I also took it to Volvo specialist not dealer who is very reasonable also said it needs CEM
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
have a look here for a small relay on the CEM that is known to go bad (not the whole CEM) post #7
http://forums.swedespeed.com/showthread ... -shuts-off
and here for DEM corrosion on the AWD system (read post Sep 26th, 2010, 20:50)
http://www.volvoforums.org.uk/archive/i ... 00774.html
- SuperHerman
- Been thanked: 207 times
One other thing to test are the shunts. Although my experience was with an XC70 - after much chasing (including rebuilt CEM) I found out a shunt was bad and it was taking everything down.
FREEBUSINESSES
- Year and Model: 2005 XC90
- Been thanked: 3 times
Yes, please, where are shunts, have a CEM issue, cleaned all corrosion from typical water damage from leaks on PC last year, solved problems, sealed CEM better, but now it won't crank and I went through everything, new starter, checked starter relay, fuse, changed battery, everything else works, just won't crank, so looking for more possibilities.
- 8999 Views
- 27 Replies
- 28062 Views
Last post by cn90
- 10 Replies
- 10451 Views
Last post by jonesg
- 5620 Views
Last post by RickHaleParker
- 9172 Views
