Thinking of lowering my V70 - any recommendations.
Want it to sit like a V70R or an 850R - 30mm? Pic below...
Don't want the ride to be too hard though - any recommendations on kits?
Also need suggestions on 17inch wheels - which do you think suit best?
Which are easiest to get hold of? Do you have any?
Alloys
850 T5 - Columba
850 T5-R - Titan
850 R - Volan
C70 T5 - Canisto OR BBS Split Rim OR Comet
S/V70 T5 - Perfo
S/V70R - Comet
Lowering a V70 1999 + 17inch Wheels Topic is solved
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
Nice V70!
No matter which lowering kit you use, it will make the ride harsher, even with stock struts and shocks. And the 17" wheels will make it far worse.
My old 850 was lowered with H&R springs (popular kit here) and had Canistos with 225/45/17 tires on it installed. It was way to harsh for me.
You have to decide if you want to trade comfort for looks, but you can't really have both I'm afraid.
This is what the combo looks like:
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
- Has thanked: 2857 times
- Been thanked: 1332 times
I put iPD lowering springs in the front of my 97 850 and I've been happy. The blue ones. Ride wasn't affected as much as I'd worried it was going to be. It's been 5 years. No complaints.
Nice one thanks...matthew1 wrote: 06 Apr 2017, 10:25 I put iPD lowering springs in the front of my 97 850 and I've been happy. The blue ones. Ride wasn't affected as much as I'd worried it was going to be. It's been 5 years. No complaints.
1999 V70 2.4 SE - UK
2008 XC90 V8 4.4 Executive - UAE
Thanks, yeah, guess you're right, just feels like it needs doing, those are 15inch wheels on mine and look way too small.850 LPT wrote: 06 Apr 2017, 10:00 Nice V70!
I found and bought some 17 inchers tonight and have ordered. Also found a coil over kit.
Your 850 looks cool too... Cheers
So - Result, I actually got hold of a set of much more modern wheels from a V50 - Cratus R Design and much later.
They needed a little light grinding to clear the hubs but I think look pretty cool - I lowered it too with R Type suspension...
- misha
- Has thanked: 155 times
- Been thanked: 432 times
How did you put v50 wheels?
They have different(WRONG) offset ET 52.5 and center bore of 63.4.
850,s,v,c,xc70 have offset ET 43!...but everything between 35-49 is acceptable.Also...center bore is 65.1.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Very pretty! I put this photo on the MVS Facebook Page. If you're not down with that, let me know and I'll remove it.bluebossa wrote: 06 Jun 2017, 13:20 So - Result, I actually got hold of a set of much more modern wheels from a V50 - Cratus R Design and much later.
- Year and Model: Lots
- Been thanked: 128 times
Looks like you have slightly decreased the track width of the car with those wheels. Any decrease gives twitchier handling at speed unless you use spacers. Careful with that.
Also you mentioned you grinded the centre hole to clear the hubs. Without accurate machining you may have vibration issues at high speed due to in accurate centring of the wheel.
However they do look great.
- 868 Views
Last post by tryingbe
- 1046 Views
Last post by MadeInJapan
- 12 Replies
- 2864 Views
Last post by JRL
- 14 Replies
- 7317 Views
Last post by JoeRV70
- 478 Views
Last post by danny chapman
