Lowering a V70 1999 + 17inch Wheels Topic is solved
bluebossa
Year and Model: 1999 V70 + XC90 2008
Post by bluebossa »
Thinking of lowering my V70 - any recommendations.
Want it to sit like a V70R or an 850R - 30mm? Pic below...
Don't want the ride to be too hard though - any recommendations on kits?
Also need suggestions on 17inch wheels - which do you think suit best?
Which are easiest to get hold of? Do you have any?
Alloys
850 T5 - Columba
850 T5-R - Titan
850 R - Volan
C70 T5 - Canisto OR BBS Split Rim OR Comet
S/V70 T5 - Perfo
S/V70R - Comet
V70 Stance.jpg (374.71 KiB) Viewed 4420 times
1999 V70 2.4 SE - UK
2008 XC90 V8 4.4 Executive - UAE
850 LPT
Has thanked: 335 times
Been thanked: 247 times
Post by 850 LPT »
Nice V70!
No matter which lowering kit you use, it will make the ride harsher, even with stock struts and shocks. And the 17" wheels will make it far worse.
My old 850 was lowered with H&R springs (popular kit here) and had Canistos with 225/45/17 tires on it installed. It was way to harsh for me.
You have to decide if you want to trade comfort for looks, but you can't really have both I'm afraid.
This is what the combo looks like:
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2857 times
Been thanked: 1332 times
Post by matthew1 »
I put iPD lowering springs in the front of my 97 850 and I've been happy. The blue ones. Ride wasn't affected as much as I'd worried it was going to be. It's been 5 years. No complaints.
Also -> Amazon link
bluebossa
Post by bluebossa »
matthew1 wrote: 06 Apr 2017, 10:25 I put iPD lowering springs in the front of my 97 850 and I've been happy. The blue ones. Ride wasn't affected as much as I'd worried it was going to be. It's been 5 years. No complaints.
Nice one thanks...
bluebossa
Post by bluebossa »
850 LPT wrote: 06 Apr 2017, 10:00 Nice V70!
Thanks, yeah, guess you're right, just feels like it needs doing, those are 15inch wheels on mine and look way too small.
I found and bought some 17 inchers tonight and have ordered. Also found a coil over kit.
Your 850 looks cool too... Cheers
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
I have S80 interceptor wheels on my car.
Also making a set of coilover so I can adjust to whatever height I want.
85 GLH, 367 whp
00 Insight, 72 mpg
bluebossa
Post by bluebossa »
So - Result, I actually got hold of a set of much more modern wheels from a V50 - Cratus R Design and much later.
They needed a little light grinding to clear the hubs but I think look pretty cool - I lowered it too with R Type suspension...
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
How did you put v50 wheels?
They have different(WRONG) offset ET 52.5 and center bore of 63.4.
850,s,v,c,xc70 have offset ET 43!...but everything between 35-49 is acceptable.Also...center bore is 65.1.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
matthew1
Site Admin
Post by matthew1 »
bluebossa wrote: 06 Jun 2017, 13:20 So - Result, I actually got hold of a set of much more modern wheels from a V50 - Cratus R Design and much later.
Very pretty! I put this photo on the MVS Facebook Page. If you're not down with that, let me know and I'll remove it.
Also -> Amazon link
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Looks like you have slightly decreased the track width of the car with those wheels. Any decrease gives twitchier handling at speed unless you use spacers. Careful with that.
Also you mentioned you grinded the centre hole to clear the hubs. Without accurate machining you may have vibration issues at high speed due to in accurate centring of the wheel.
However they do look great.
