Whirring noise when turning on S70
romania1
Year and Model:
Post by romania1 »
Yet, *another* :roll: problem on my Volvo, that I love dearly!!!
Okay, hopefully JRL will be able to help me again!!! :D I have searched through this database and not found anything that accurately describes my "problem"
My problem is this: Whenever I am turning to park, the steering makes a kind of "whirring" noise. This is the only time we hear this noise, when we are parking the car, or slowing to turn into the driveway, or something of that nature. Whirring is the only way I know to describe it. It doesn't sound like rubber on metal, or metal on metal. I wish I could make a sound clip of it and upload it so that you guys could hear, what I am probably not describing adequately enough.
The fluid levels are fine for the PSF. Could it be some bad bearings somewhere?
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Well it sounds as if it's in the PS pump or the rack. The racks DO go bad on these cars quite often
If it IS a rack, fcpgroton sells an aftermarket rack that's actually quite good at a decent price
romania1
Year and Model:
Post by romania1 »
Thanks for the info. How do you tell for sure whether it's the PS pump or rack?
JRL
Post by JRL »
romania1 wrote:Thanks for the info. How do you tell for sure whether it's the PS pump or rack?
It's not always so easy, (if no obvious leaks), you should find a GOOD mechanic to help diagnose
romania1
Year and Model:
Post by romania1 »
Well, finding a good mechanic is easier said than done.... I live in Lousiana, and our politicians/politics ain't the only thing that's crooked!!! :!: :?
mrreilly
Year and Model: 1998 Volvo S70 GLT
Post by mrreilly »
I had the same whining noise with my can when I got it. It ended up being the rack. And it cost me about $850 to be done at a shop. i'm sure I could have done it. But this was before I had built up my confidence from doing all my other repairs. Oh well.
So my guess is the rack. I haven't heard anything in the way of the pump going bad yet from most others.
Good luck.
1998 Volvo S70 GLT Black/Tan
Approx. 173,000 3/27/2010
My major repairs:
Timing Belt, Left&Right Control Arms, Tie-rod ends, Lower Engine Mount, Engine Stabilizer Mount, IPD Sway Bar Links, Brakes , Head Gasket, PCV System, Turbo Rebuild, and more
JRL
Post by JRL »
mrreilly wrote:I had the same whining noise with my can when I got it. It ended up being the rack. And it cost me about $850 to be done at a shop. i'm sure I could have done it. But this was before I had built up my confidence from doing all my other repairs. Oh well.
Good luck.
If it proves to be a rack, Groton's is about $230 vs. Volvos for $5-600
and it's good quality
hausmeister
Year and Model: 1995 850T5-R
Has thanked: 278 times
Been thanked: 86 times
Post by hausmeister »
You could always replace the PS Fluid as a start... not expensive and might help.
I had some problems with the fluid, even though I changed it not long ago(also it still looked good); put in new ATF and it was quiet again. Don't know if there is another problem, but it has been quiet since.
850 T5-R '95 auto Image
JRL
Post by JRL »
hausmeister wrote:You could always replace the PS Fluid as a start... not expensive and might help.
It's supposed to be ATF, perhaps someone added regular "PS fluid" in yours
hausmeister
sorry, I didn't mean it that way. I know, and it was atf in there... don't know what happend. Was maybe 6months old...
I'm just thinking he should try to replace it before doing anything expensive?
