2004 v70 2.5t pulls right when accelerating
68lemans462
- Year and Model: '04 V70
- Been thanked: 5 times
Car has 119k and pulls to the right under acceleration. . Ball joints and tie rods feel tight when jacked up. Last time the volvo shop had it they told me it needed lower motor mounts. Could this be causing the problem? If not any other suggestions? I included a pic of the car. Thanks
- 20170628_192345.jpg (2.37 MiB) Viewed 3890 times
68lemans462
One more detail is that I just installed new tires and the problem is definitely more pronounced with the new tires. It also drives alot better in general. Have had it aligned within last 20k
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
At 120k you have the lower torque mount (the small one right at the bottom from of the engine) as well as the upper torque mount that go bad. Check both of them. The lower one I think it's harder to replace.
I would then look into tire pressure, then control arms as mentioned above. An alignment wouldn't hurt but not sure that would cause pulling only under acceleration.
Hit the forum to find which aftermarket parts are worth buying
vtl
- Year and Model: 2005 XC70
- Has thanked: 114 times
- Been thanked: 603 times
I had a 02 V70 FWD with everything new under the hood, in suspension, in steering (well, besides all the bushings in rear end). It pulled right and only under hard acceleration. No one moron at alignment shops paid attention to what thrust vector is set to, so I ended up learning how all this stuff works and fixed the problem myself, i.e. set rear toe-in correctly. All they do in shops in MA is front toe.
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 78 times
When you accelerate, both front wheels are trying to thrust forward. But since they are anchored to the chassis via the control arms, that thrust translates to an arcing motion forward and inward. If the control arm bushings are sloppy you will get more toe-in when accelerating, and toe-out when applying the brakes. So if the LH CA is more worn than the RH, the car will pull to the right when accelerating.
vtl
Car is wondering a lot if LCA has torn bushings, it changes direction unpredictably every time it hits even small road imperfection. You'll be fighting with steering wheel at highways speeds if the bushings went bad, this will be your primary concern.
- Botbasher
- Year and Model: 98 "R" & 03 T5 V70
- Been thanked: 4 times
Hey ya'all.... let's not forget the sub-frame bushings. These will allow the same thing to happen and are VERY overlooked in this type of issue. If the LCAs are important... so are the things that the LCAs mount to! Check your sub-frame bushings too!
I found my right side ones had been turned to goo by a leaky PS fluid. I replaced them and now the car pulls slightly to the other side as someone did an alignment while they were gooey!
K "bushed" S
K "bushed" S
Never become a pessimist. A pessimist is correct oftener than an optimist, but an optimist has more fun, and neither can stop the march of events.-Heinlein
We have met the enemy and he is us.-Pogo
If speed kills, do brakes give life??
- 587 Views
- 22 Replies
- 3720 Views
Last post by plumsmooth
