A Deer killed my Beautiful 2000 V70XC /SE
shiloh51933
Has thanked: 28 times
Been thanked: 17 times
Post by shiloh51933 »
I found another V70XC but it's not an SE variant so that means 15inch wheels instead of the 16's the SE has and smaller brakes. Has anyone swapped the SE wheels and brake calipers /rotors over the a base V70XC and what was required?
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
bskeels
Year and Model: 1997 Volvo 960
Been thanked: 3 times
Post by bskeels »
as far as the difference in the brakes, the caliper bracket is bigger, both cars use the same caliper
the 16" wheels will fit as they have the same bolt pattern, and the rotor from the se will have to be used
The Fleet
2012 Ram 2500
97 Volvo 960
98 V70 AWD (208000+)
66 Volvo 122s sedan project
98 Volvo V70 XC (151,000+) parts car
08 Volvo V50 T5
"Human history becomes more and more a race between education and catastrophe" - H. G. Wells
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
Along with the caliper bracket, the flexible brake line also needs to get swapped over!
Current Volvos:
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
Killed?
That just looks like minor surgery from this end of the net.
There's probably a donor car out there with a blown engine
that would turn this into a simple weekend body parts swap.
Teddy1975
Year and Model: 2007 V50
Been thanked: 7 times
Post by Teddy1975 »
Just need a hot iron and it'll smoothen out the wrinkles nicely :D
Sad to see it though.
Current: V50 2.0D, 2007, 6 speed manual
Previous: 850 2.0L N/A, 4 door 1996 manual, 740 2.3L N/A, 5 door 1992 manual, and S70 2.5T 1999 manual
Been thanked: 4065 times
If that frame isn't bent, I think I would call Erie for matching color parts and put it back together
Hopefully for not too many bucks..
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
This is a job of an hour or two to replace all damaged parts.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
shiloh51933
abscate wrote: 01 Jul 2017, 13:01 If that frame isn't bent, I think I would call Erie for matching color parts and put it back together
The front end is shot, wouldn't drive straight, the radiator /intercooler/condenser sandwich is crushed, broke oil cooler lines and trans cooker lines, radiator fan, turbo plumbing up front, tore up R/F half shaft boots.
My AWD has bad Angle Gear so I rear rear drive shaft. This '98 literally on has 100, 021 miles on odometer, the AWD is solid, the interior is perfect, paint is perfect and motor is good
shiloh51933
misha wrote: 01 Jul 2017, 13:25 This is a job of an hour or two to replace all damaged parts.
It not just body parts, everything up front is crushed and I found a V70XC w/100k on odometer w/good AWD, even the leather drivers seat is in perfect condition. Most of all I'm too busy for ths t shit. I love the V70XCSE, I searched for month's to find a good one,
shiloh51933
:shock:
FLXC90 wrote: 01 Jul 2017, 11:12 Along with the caliper bracket, the flexible brake line also needs to get swapped over!
TY for answeringmy questions, if I remember correctly my last '98 V70XC had a smaller rear caliper w/smaller brake pads. The rear pads/caliper was a fixed caliper that had 2 pins and you slid the pads out without having to remove caliper from rotor.
