doing the evaporator! Last questions
kaneelschep
Year and Model: '96 850 2liter t5
Post by kaneelschep »
I am very happy I didnt do the evaporator job yet.. There were some rainy days.
Because just now the heater core gave me a subtle yet very clear hint it demanded attention/replacement too.
After pushing the gas a bit, the car suddenly heavely smelled like coolant.
The floor at the passenger side got wet and the vents began smoking a bit later.
I topped of the coolant and drove home. maybe 2km.
It felt and smelled quite hot when I opened the hood, but the gauge never went up further than normal.
So I guess no problems.
I ordered a nissens heater core and will get the 2 rubber o rings... ;)
kaneelschep
So I got the dash out, ready to take the heater box out.
But I cant seem to get the ac lines loose.
I got the tools. 5/8 and 3/4 seem to be the right sizes.
It goes around the line well, you squeeze it in the round part.
Then I can take the line apart a bit, till I see the flared bit of the tube.
But it just wont go any further.
What am I doing wrong here?
kaneelschep
Forget it. persistence prevailed.
I just needed someone to pull the other side too.
Got it all out through the cable spaghetti.
The original heater core was still in the car :D.
Didnt get the evaporator out yet, because diner..
kaneelschep
Evaporator was original too. It both had a '95 date.
Looked like crap!
And there was water in the hole for the fan..
Some pictures:
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Keep it up!
Try to find a cabin filter assembly from a 1998 to 2000 model V70/S70. It will protect your new evaporator by preventing the entrance of all that crud.
Has thanked: 1614 times
Been thanked: 4078 times
I have that same hood accessory in grey and white
kaneelschep
:) I have 2 more of those, A red one and a white one. They constantly hang around me when I am at the car.
Sometimes while doing a quick testdrive, a cat will still be sleeping on the back seat.
Had to wait till 19:00 today for the postman to deliver my heater core. So I cleaned the air box. The old foam became sort of a brown sticky snot. Quite disgusting. Didnt have any foam and couldnt really find a store wich sold it.
Even the rubber between the heater core box was flat hard and pushed out.
So I replaced it all with the strips you put on windows/doors against the draft.
Quite good stuff. It looks good and will probably seal well.
Anything better than the snot.. ;)
Anyway. The airbox is back in the car again. Was easier than getting it out.. :)
Only I seem to have lost something. It cant be far, but I forgot what it was. Or something was even there.
So this:
It goes in the hole on the green connecter.
Has to be a temperature sensor for the incoming air. I don't remember,her that on my 99.
kaneelschep
Thanks!
Found it. It rolled under the car.
I Cant seem to find any 3w dashboard light at the typical stores. Which is the larger bulb for the fuel, temp gauge
They all sell the 5w instead..
Is it a problem if I use 5w instead of 3w?
kaneelschep
Dash, fan and steering wheel and covers are back in. again a lot easier then getting it out.
But this time I left the top off.
Anyone doing this, I would recommend taking the top off before taking the dash out.
It saves a lot of weight, and it will make it a lot easier to move around.
Also without the top, you can actually see all the cables and mounting posts. Wich is a big plus.
Now I just have to wait for a proper bulb. So I can finish the dash and airbag. Then I can start the car and see if there is no leakage at the heater core.
Then finish the rest.
