One day i lost power to both my blinkers and then my hazard lights. It started as one turn signal direction went out first, then the rest, including my brights. I checked the fuses, what else should I be looking for? My running lights appear to be working, not sure if theres a short somewhere that would cause everything to go out.
Ryan
98 v70 awd
lost power to blinkers, brights and hazards
- Been thanked: 504 times
Ignition Switch (electrical part on the left side of steering wheel).
These were the symptoms I had.
New ign switch ($55 at Volvo dealer) fixed the issue.
- Has thanked: 311 times
- Been thanked: 817 times
+1 to the ignition switch. Jiggle the key back and forth, see if that affects it.
- Has thanked: 2203 times
I agree with the other guys the ignition switch 'wiggle' may work to highlight a bad electrical portion of the ignition switch.
If that makes no difference, then the next think I would look at the turn signal lever for bad contacts or damaged/broken wires.
Do you have cruise control? Does it work? It is part of the same switch.
Last think to try is the hazard switch unit itself.
- 2024 Views
Last post by PeteB
- 1978 Views
Last post by stone36
- 596 Views
Last post by Nashsurecanpaint
- 1466 Views
Last post by regent
- 906 Views
Last post by 93Regina
