When I come to a quick stop the transmission takes a long time to shift down into first gear. In normal driving the shifts are usually O.K.
I've done one preliminary fluid change with Dextron III. I understood that the 2000 model used Dextron III. Am I wrong? Does it have to have a special Volvo fluid?
Thanks in advance for and assistance!
2000 C70 Transmission Downshift Question
- Has thanked: 2212 times
- Been thanked: 1853 times
Which transmission do you have? 4 Speed or 5 speed auto?
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
Dex III is correct. I would do a series of drain and fills, not just one, and see if anything improves. The Valvoline MaxLife ATF is really good as is Mobil's synthetic ATF.
I haven't had much look saving a dying trans but it's been known to work so I wish you luck. Let us know how it turns out long term.
