Need a part number that Volvo seems not to provide or someone that has a spare. First time poster. I’ve been working my way through a 1994 Volvo 940T’s issues. This week it was the gasket on the extension housing and transmission mount. When I pulled the extension housing the pipe that routs oil to the bearing at the rear of the extension housing came loose. This pipe has three pieces a long pipe and rubber joint and a very small pipe to join to the transmission. Unfortunately, when the pipe came off this small pipe piece bounced into a deep crack in my garage floor (Broken cement due to age and soil.) Retrieving it is not an option without jackhammering the cement.
Anyways does anyone know the part number for this, it is item 8c on this page https://www.volvopartswebstore.com/show ... evel=24679
I put it back together without the oil pipe, but I expect the bearing with go within the next 10k miles due to limited lubrication and I’ll open it back up at that time and reinstall the pipe if I can find the part. Any help will be greatly appreciated.
940 AW71 92+ Bearing Oil Pipe Connector Part
- 1437 Views
Last post by 88760RICH
- 4830 Views
Last post by darrylrobert
