Car won't start, worked yesterday. 2000 V70 manual
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Don't pay local dealer prices. FCP's reman would probably reach you in N.H. in a day or two and is probably fine. Crazy to pay a dealer $350 for a reman starter. Local NAPA parts store could be an option too.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- FireFox31
- Has thanked: 159 times
- Been thanked: 303 times
New starter installed. Car started right up. It even starts faster with this new part.
The old starter must have died from corrosion to the 2" cable between the solenoid and the motor. After removing the starter, I pressed on it and it crumbled. It must have been unable to deliver the electricity due to its corrosion.
How can we prevent this corrosion on our new starters, which are the exact same design as the old ones? Petroleum jelly or hot glue on the exposed ends of the wire? Thanks.
FireFox31
Alas, save another replacement date on August, 2034.
Maybe the Bills will beat the Cubs for the Stanley Cup that year.
- E Showell
As I have said on here before, I have replaced a starter without removing anything else, but it was not fun.
'95 855 auto (sold)
'95 855 auto (sold)
I've had a couple of cars have starters fail this way. One common symptom was a slight delay, about 1/2-1 second between turning the ignition switch to start/crank and the actual cranking action. It usually preceded failure by a few months
A starter bypass won't help you with this of course, since the current between battery and motor is interrupted by this failure. That was the useful diagnostic here, if course
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
You could spray the area with undercoating or yearly with ACF 50 as a preventative measure - but ultimately, it is going to fail eventually. I figure if I get 10 or more years on a starter, it owes me nothing.
richc233
- Year and Model: V70XC, 2000
I just solved what sounds like the exact same problem on my 2000 V70XC Turbo, and the culprit was a bad/dirty connection AT the starter solenoid - the thin wire that supplies 12v to the terminal when you turn the key. I tried the other things mentioned above, including the remote starter terminal, but the problem is that connecting to the remote terminal still sends the 12v to the same wire that connects to the starter terminal.
In the V70 Turbo it is pretty hard to reach the wire/terminal, but when I maneuvered my hand to reach the cable it felt kind of loose. I moved it around a bit then tried to start again, and it actually made a sound like the solenoid activated for a second. I then tried pulling the cable off, but it got tighter while pulling it and it made a better connection...and it started right up. I still have to clean the terminal up and tighten the slip on connector, but at least it is working now.
Hope this helps someone out that is still keeping there V70 running!
Thanks,
Rich
Thanks,
Rich
- greg850r
- Year and Model: a long list
- Has thanked: 5 times
- Been thanked: 26 times
If the car you jumped it from saw a draw and you still get no cranking I'm with abscate. You have a starter problem.FireFox31 wrote: 24 Aug 2017, 18:05 Then I disconnected my battery and used jumper cables to connect the wires to my running Mercedes. I tried remote starting it with the key on position II. Of the four times that I tried, I think I heard the Mercedes strain slightly on two of the tries.
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan -wrecked, ouch
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
02 Sportster Custom -sold
Parts cars come and go
99 C70 Convertible
96 850R wagon
96 850T wagon
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
Old thread alert!
- SonicAdventure
- Year and Model: 1996 850 wagon
- Has thanked: 59 times
- Been thanked: 12 times
Not sure if this helps, but does a manual have any sort of PNP switch or any type of switch that kills current to the starter if it malfunctions?
- 1800 Views
Last post by rspi
- 4196 Views
Last post by oragex
- 18 Replies
- 3342 Views
- 17 Replies
- 6279 Views
- 943 Views
Last post by Craigd2599
