Hello. Just got my '98 S70 back last night from my trusted mechanic (at least he was trustworthy in the past) and he was supposed to just install for me a new radiator. Instead they broke the thermostat housing along with the job and when I picked it up and turned the key, I see that nice, bright orange "check engine" light illuminated. The engine also idled very funny and I drove it home like this.
Just went out to my local parts store and they pulled the following codes for me:
P0300: Random/Multiple Misfire detected.
P0302: Cylinder 2 misfire detected
P0303: Cylinder 3 misfire detected
P0304: Cylinder 4 misfire detected
P0172: Bank 1 system, too rich.
P0455: Evaporative emission system leak detected
If anyone can suggest my next move, I would greatly appreciate any assistance. Just wrote that trusted mechanic a check for over $600 and I don't have a good feeling about going back.
Thanx!
Mulitple Engine Codes pulled...
Mr. Detail
- Year and Model: 2002 V70 N/A
- Has thanked: 157 times
- Been thanked: 6 times
- Has thanked: 1611 times
- Been thanked: 4072 times
Clear all the codes and see what comes back.
Talk to your mechanic while the job is still fresh, so you have a basis for discussion. Mechanics don't break cars willingly, something simple is probably loose or forgotten.
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
Since the job was radiator, and the thermostat housing, I would look at purge valve hoses on the shroud, and the elbow for the PCV on the manifold near the thermos housing. Also, moderator is right, check while fresh, they may find something they missed or didn't seat well-enough. If they're decent, they'll give it a good looksee and not bill you. (unless they find something unrelated causing it)
edit-something unrelated, how fresh are your tune-up parts? when was PCV done last? Is there oil in your distributor?
Current Volvos:
Mr. Detail
My tune up parts are not fresh at all. I kind of get a kick out of your responses about oil in my distributor. I took the car to my mechanic on Monday night and picked it up on Thursday. So your are stating that oil could be in my distributor after the car was fine when dropped off and after sitting in a shop for three days suddenly has oil?
Cars degrade slowly over time. people commonly post..." It was running fine then suddenly....."
Well, it wasn't running fine. Plugs cap and rotor are 30,000 mile service items, seals leak, oil gets places it shouldn't and one day it bites you. Unless you paid about $500 in diagnostics to go through your engine management system, your mechanic didn't check any of that stuff.
- Has thanked: 312 times
- Been thanked: 818 times
Oil in the distributor is pretty common, it happens from a blown rear cam seal. That was my first thought too - is there oil under the cap?
For example, maybe the mechanic reconnected a PCV hose incorrectly.
- Has thanked: 2209 times
Not sure why they managed to break the thermostat housing when changing a radiator, unless they were trying to change the thermostat. The housings can be fragile for the thermostat with age and the 2 bolts that hold it down can become stuck in the threads and cause the housing to crack when removing with too much force. Not an uncommon issue, but a shit happens one.
Not sure why they would have touched the PCV system either in the process. One possible issue is the ECT (engine temp sensor) which is in the thermostat housing. Check they connected it OK and the wiring is good as it becomes brittle with age at the connector which is on the back of the power steering pump. Also check they connected all the connectors on the top of the fan shroud correctly and they are seated.
Have you spoken to the repair shop? What have they said?
The distributor cap/cam seal issue is a possible coincidence, but at this point I am not sure that is the issue, but a fairly easy check. Remove the air filter cover to get room and undo the 3 screws/bolts that hold the cover on and have a quick look.
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 129 times
I'd speak with the shop. It could be any number of things and a good shop won't shy away from giving it another look.
2023 Lexus RZ450e -66k
- FLXC90
Exactly where I was going with my comments, oil in the distributor worsens over time. Also it could explain the scattering of misfires It just becomes a matter of enough to start fouling the rotor. The PCV nipple right near the thermostat housing is already a known culprit for leaking, if it was merely bumped it could worsen symptoms miraculously, overnight. As far as the purge valve and hoses, same thing, they took them loose at least to change radiator: known culprit for P0455.
Scot850 makes a good point also, ECT wiring. Does the temp gauge seem to behave normally? If the engine doesn't realize it has warmed up, it will effectively run like the "choke" is on. could cause stumbles and misfires. All simple fixes, all "feces occurs" items for the shop, all agonizingly frustrating for you. I sympathize, I'm (very lazily) chasing P0455 myself. And I just changed out the hoses on my purge valve, they were deteriorated to the point of feeling gooey. Also found a manifold elbow, still have the code on my 235000mi $300 POS70. still fires on the first try every time for three plus years now.
Current Volvos:
- Roger_850T
- Year and Model: 854T 1995
- Been thanked: 26 times
Maintenance aside, it does seem suspicious that it started misfiring after this work.
I think the "System too rich" code is a result of all the misfires.
With the Evap code as well as the misfires, I am thinking that a lot of extra air is getting in there. I think an air hose is not on right, not tight, or a vacuum hose off, or something like that.
You don't say if its a turbo or not, but they would have needed to take off the air hoses to the intercooler to replace the radiator. A loose clamp on the intercooler hose could cause the hose to partially come off.
I'd look under there for anything that looks amiss or disconnected and see what I can see.
Hope this helps!
Roger
Hope this helps!
Roger
11 XC60 137k
08 V50 Project... Still in pieces
05 XC90 V8 213k
95 854T 350k Still my favorite daily driver
02 V70 186k+ Gave to my daughter, still going strong
03 S80 111k (crashed, but driver walked away unhurt)
93 945T 217k (gone to be parted out)
87 245 300k+ sold, still going afaik
84 264 Diesel, RIP at 160k
78 242 manual everything.
73 P1800ES, fun until the rust set in...
05 XC90 V8 213k
- 515 Views
Last post by Mr. Detail
- 12 Replies
- 2595 Views
- 1105 Views
Last post by cloaked45
- 1326 Views
Last post by Brucebo
- 5593 Views
Last post by ignatz
