Help,
I just pulled the engine/transmission assembly out of my 2009 Volvo S40. The crank was turning fine when I removed the harmonic balancer before pulling the engine.
I've:
Drained the transmission fluid.
Removed the starter.
The engine/transmission is currently suspended from a lift.
Timing belt is still installed.
I wanted to turn the crank in order to remove the torque converter bolts, but the crank seems locked solid. I even tried a breaker bar on the crank nut. With the above configuration is there some sort of interlock somewhere locking the crankshaft/transmission? I seem to be stuck.
2009 S40 engine pulled, crank won't turn
- RickHaleParker
- Been thanked: 980 times
Did you turn the crank clockwise or counterclockwise? The timing belt can slip if you turn counterclockwise.
Active
Past
Past
- RickHaleParker
You might try letting it down to the floor or a table so the bell housing is not carrying the full weight of the transmission.
I am thinking there might be just enough flex to bind it up.
Active
Past
Past
Brucebo
- Year and Model: 850 '96, S70 '99
- Has thanked: 3 times
- Been thanked: 5 times
This engine suffered a block crack and all the coolant ended up in the crankcase. What happened was I waited too long and the cylinders and rings rusted up and seized the crank. I ended up pulling the oil pan and bottom bearing to drop the crankshaft in order to get the torque converter.
See my recent posting today for "the rest of the story".
- 970 Views
Last post by tobotech
- 1204 Views
Last post by shiloh51933
- 4888 Views
Last post by oragex
- 3610 Views
Last post by Empathron
- 1814 Views
Last post by erikv11
