ac compressor wont shut off
yellow95
Year and Model:
Post by yellow95 »
Worked fine up until yesterday morning. I turn the ac off and it still ran. removed the relay still ran, unplugged low pressure switch. Still ran. Only stopped when I removed the fuse. Any clue as to what to check?
Gary
1997 T-5 Wagon and big aspirations.
I travel all rainy roads and hydroplane thru life.
Has thanked: 2199 times
Been thanked: 1851 times
Are you sure it was the AC compressor? Does it no need the engine running to drive the clutch to drive the compressor? Are you sure it was not the engine cooling fan running as it is supposed to do to cool the under hood temperature? That can run for several minutes after switching off.
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
If you removed the relay then removing the fuse shouldn't matter.
If I were the betting type, I'd bet the clearances in the clutch are too close or it was slipping, heated up and then grabbed...
Has thanked: 1609 times
Been thanked: 4065 times
Are we discussing the fan or the compressor?
wizechatmgr
If the issue is a fan -- are we talking about the blower in the passenger's compartment or the fans on the radiator. If the latter, it may run for a while if the coolant is hot enough. Double so on a hot day with stop and go traffic.
That is what I asked at the beginning, as I can't understand how the AC compressor can run on if the engine is stopped, as the serpentine belt needs to run for it to turn the compressor. Hence (maybe wrongly) the supposition that it is not the AC compressor but actually the engine cooling fan doing it's thing to reduce under hood temperatures to lessen the chances of overheating under the hood. If that is the case and it is the engine fan, it is meant to do that.
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
I hate it when alien craft levitate posters and returns them to that other planet right in the middle of a posted issue.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
From his description, it's really the a/c compressor that keeps running even with the switch turned off. That's one resilient compressor, could it be the clutch plate got stuck on the pulley for some reason?
jimmy57 I can feel ya, small consolation, they are driving Volvo on other planets :)
mrbrian200
Has thanked: 7 times
Been thanked: 84 times
Post by mrbrian200 »
wizechatmgr wrote: 07 Sep 2017, 22:23 If you removed the relay then removing the fuse shouldn't matter.
Unless there were a short in the wiring. With the relay pulled already if pulling he fuse disengages the compressor clutch that would mean the short would have to be between two specific wires - the power feed wire coming from the fuse shorted to the relay output that goes to the compressor right around or inside electrical distribution box.
wizechatmgr
I'd be willing to bet he fixed it.
