Worked fine up until yesterday morning. I turn the ac off and it still ran. removed the relay still ran, unplugged low pressure switch. Still ran. Only stopped when I removed the fuse. Any clue as to what to check?
Gary
ac compressor wont shut off
- Has thanked: 2197 times
- Been thanked: 1851 times
Are you sure it was the AC compressor? Does it no need the engine running to drive the clutch to drive the compressor? Are you sure it was not the engine cooling fan running as it is supposed to do to cool the under hood temperature? That can run for several minutes after switching off.
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
If you removed the relay then removing the fuse shouldn't matter.
If I were the betting type, I'd bet the clearances in the clutch are too close or it was slipping, heated up and then grabbed...
- Been thanked: 4064 times
Are we discussing the fan or the compressor?
- wizechatmgr
If the issue is a fan -- are we talking about the blower in the passenger's compartment or the fans on the radiator. If the latter, it may run for a while if the coolant is hot enough. Double so on a hot day with stop and go traffic.
That is what I asked at the beginning, as I can't understand how the AC compressor can run on if the engine is stopped, as the serpentine belt needs to run for it to turn the compressor. Hence (maybe wrongly) the supposition that it is not the AC compressor but actually the engine cooling fan doing it's thing to reduce under hood temperatures to lessen the chances of overheating under the hood. If that is the case and it is the engine fan, it is meant to do that.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
From his description, it's really the a/c compressor that keeps running even with the switch turned off. That's one resilient compressor, could it be the clutch plate got stuck on the pulley for some reason?
jimmy57 I can feel ya, small consolation, they are driving Volvo on other planets
- mrbrian200
- Has thanked: 7 times
- Been thanked: 84 times
Unless there were a short in the wiring. With the relay pulled already if pulling he fuse disengages the compressor clutch that would mean the short would have to be between two specific wires - the power feed wire coming from the fuse shorted to the relay output that goes to the compressor right around or inside electrical distribution box.wizechatmgr wrote: 07 Sep 2017, 22:23 If you removed the relay then removing the fuse shouldn't matter.
- wizechatmgr
I'd be willing to bet he fixed it.
- 674 Views
Last post by volvo06
- 2161 Views
Last post by BEJinFbk
- 2081 Views
Last post by RLBOHNER38
- 17 Replies
- 2704 Views
- 563 Views
Last post by vtl
