Tow 2016 with dolly?
NEHOG
Year and Model: 2016 S80
Post by NEHOG »
I spend a lot of time on the road with my RV. We'd decided to take the S80 with us this winter trip (five months of exploring) and we use a tow dolly. Any hints or suggestions? Things I want to avoid:
The car applying brakes/parking brakes for whatever reason.
The alarm/security system activating due to angle and vibration.
Anything else that might become a problem.
Anyone do this, and any thoughts.
The 2016 S80 is FWD, with electric parking brakes on the rear wheels. Front wheels are off the road on the dolly.
Dora with Saab.jpg (119.04 KiB) Viewed 760 times
(I know, that's a Saab--forgive me!)
My name is Peter, and I'm never going to grow up!
2016 Volvo S-80
1990 Saab 900T convertible
1988 VW Cabriolet (original owner.)
2006 Holiday Rambler Ambassador motor-home.
jimmy57
Been thanked: 320 times
Post by jimmy57 »
turn ignition off and then remove the F1 and F2 fuses in the box in left rear side of the trunk fusebox. Those ar the electric park brake fuses. You could remove ground cable from battery too if you like instead. The car doesn't have steering column lock so that is not a concern. If you remove fuses then put them back before key on to avoid cluster messages and blinking p brake light.
NEHOG
Post by NEHOG »
Thanks, I was thinking along those lines. Disconnecting the battery ground might be better as it will disable the security system from getting tripped. (Not sure if that is a problem or not...)
2016 Volvo S-80
