1989 volvo 740 gle need help
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
BARRYALLEN50
Year and Model:
Post by BARRYALLEN50 »
my 89 volvo 740 gle needs some help. as im driving the gas get cut off somehow. but will re-start up and keep going. just started happening. i have checked the fuel pump and filter and its not these im told. im told electrical problem but not sure where to start. lights and all electical stuff stays on the gas seems to shut off then start up again. sometimes when ideling it will just shut down. and will be very hard to start. other times just fine. not missing runs great. no loss of power. can anyone help with this thanks much :?:
Kmaniac in California USA
Year and Model:
Post by Kmaniac in California USA »
First of all, what engine, what transmission and how many miles? Have you owned it a long time or is it a recent acquisition?
Your car needs two things to run, Spark & Fuel. Lose either one and the car doesn't run. The symptoms you describe could indicate a loss of either item.
Check your fuse box and note the condition of the "in-tank fuel pump" fuse (fuse #11?). If blown, you will need to replace BOTH fuel pumps and BOTH fuel filters together (Yes, there are two of each.).
You say that you were told this was an electrical problem. Who told you this and how did they diagnose the problem??
Please enlighten us with more detail and we will ponder some more.
Chris the "K MANIAC"
1986 740 GLE
(5) 1964 Chrysler 300-K's
BARRYALLEN50
Year and Model:
ENGINE IS B230F 140 HP 98000 MILES I DONT KNOW HOW THEY CHECKED BUT IT WAS AT A SERVICE STATION THAT DOES REPAIRS. THEY WOULD NOT TELL ME MUCH. ONE GUY THERE SUGGESTED THE COIL COULD BE THE PROBLEMS. I WILL CHECK THE FUSES. SORRY FOR THE CAPS KEY STUCK THANKS AGAIN FOUR CYL. AUTOMATIC
BARRYALLEN50
Year and Model:
WILL THE CAR RUN IF THE FUSE IS BLOWN. I CAN HEAR THE PUMP WORKING
BARRYALLEN50
Year and Model:
FUSES ARE ALL OK NO PROBLEM HERE
CarVolvo
Year and Model:
Post by CarVolvo »
usually its the relay.. in the fuse panel.. big white one.
Should always have a spare.
THE FLEET!:
93 854 GLT 20v non-turbo 435,000 KM +
94 854 20v non-turbo 215,000 KM ..new engine
87 745 B230 non-turbo 250,000 KM (newest edition Jan '07)
86 244 GL B230 non-turbo 460,000+ KM
BARRYALLEN50
Year and Model:
i will give this a try thanks much
