idle rpm on 850 Topic is solved
carlo
idle rpm on 850
Post by carlo »
hi,
just got this 850 wagon with 115k, manual transmission - nice!
what's the correct idle rpm on 850? mine '96 is about 1,000 - i think that's a bit high. any idea how to adjust it or how to investigate?
cheers & thanx!
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2660 times
Been thanked: 1248 times
Post by matthew1 »
Make sure the air intake path is clean and free of gunk. Make sure air filter is clean/new. If you can get to the throttle body, spray some cleaner in it if it has a tar-like resin. All those will cause high idle.
Also -> Amazon link
carlo
Post by carlo »
matthew1 wrote:Make sure the air intake path is clean and free of gunk. Make sure air filter is clean/new. If you can get to the throttle body, spray some cleaner in it if it has a tar-like resin. All those will cause high idle.
matthew,
thankx for the tip. the air filter is clean. i'll try the intake next.
carlo, nyc
carlo
Post by carlo »
cleaned air intake and throttle valve, but no change in decreasing idle rpm.
(also changes spark plugs and wire set, rotor cap and distributor).
is it perhaps adjustable through the accelarator linkage or through throuttle link?
potroast
Year and Model:
Post by potroast »
I've got a 1994 Volvo 855, and it idles between 800-1000 RPM. I have accepted this as normal due to our very weak engines (especially at lower RPM).
My friend's 1993 Volvo 854 idles within the same range, as well.
matthew1
Site Admin
Post by matthew1 »
You know, mine idles at 900 or very close to 900. I should have posted this earlier after truly reading the original question, but my brain was in the OFF position that day I think.
Also -> Amazon link
