New Nissens radiator - drain plug question
krenekj
Year and Model: Wife says too many
Has thanked: 2 times
Post by krenekj »
I just finished replacing my radiator with a Nissens - documented here - in my 99 S70 NA MT.
The drain plus is a simple twist off thumb screw that does not take much force to loosen. Do I need to secure it any further? I don't have any experience with this type of drain plug and I'm not sure if it will work it's way loose.
Thanks.
93 240 Wagon
99 S70 NA 5sp
02 V70 NA
18 V90CC T5P*
theWIFES_S70
Year and Model: 1998 S70 base
Has thanked: 61 times
Been thanked: 37 times
Post by theWIFES_S70 »
Do you have this type of radiator petcock?
Mine broke when I was flushing fluid over a year back.
viewtopic.php?t=75250
Horrible design if you ask me. Mine weeps, but that's because I broke it and replaced it with the only one I could find that has a few less threads than the Volvo one. I was supposed to JB Weld it but it's stopped weeping (as much). I wouldn't worry about it. But I also wouldn't open and close it very much. We're lucky that it's so easy to remove that lower radiator hose on our car. When I get around to swapping out my heater hoses I will drain it and JBWELD it.
Retired:
2015 Volvo S60, T5, 85K
krenekj
Post by krenekj »
No, the plug looked similar to the one below, with an embedded washer, thumbscrew and long threads. It only makes a 1/2 turn or so before you can pull it out.
93 240 Wagon
99 S70 NA 5sp
02 V70 NA
18 V90CC T5P*
Has thanked: 1613 times
Been thanked: 4075 times
Thumb screw type covered here
viewtopic.php?f=1&t=79580
