2001 S60 2.4 Air Conditioning
DGoState8
Year and Model:
Post by DGoState8 »
I'm new to the forums and hope I post this correctly.
I drive a 2001 S60 2.4 with 117k miles. Approximately 4 months ago my air conditioning ceased functioning properly. When I turn it on, it will blow somewhat cold for 10 to 20 minutes and then will stop blowing cold and all I get is a warm fan. Anyone else have this problem? Possible causes?
Thanks,
Dan
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Most obvious is to have a good A/C person check your gas to see if you are low. If it is, have him add some. The port to add on your car, I believe is a high pressure port, that's why you really shouldn't do this yourself. If you get the same symptoms again, then you have a leak which could be detected through gas with a dye in it. Good luck.
ppcgm
Year and Model:
Post by ppcgm »
I've been having the same problem with my 960 and have heard the same description as you posted from so many Volvo owners that I've come to believe it's a shortcoming in the design of the system.
The previous owner of my car spent almost $4,000 trying to fix this, replacing every component in the climate control system over a two year period. I'm going to live with it.
DGoState8
Year and Model:
Post by DGoState8 »
I had the gas replaced and its still having the same problem. Is my only option to pay the dealer to check it out?
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
DGoState8 wrote:I had the gas replaced and its still having the same problem. Is my only option to pay the dealer to check it out?
Someone has to, these problems can be very frustrating.
I just had the same thing in a car I won, the A/C just didn't cool quite enough.
There is a line (can't for the life of me remembe what it's called) but that was a bit clogged, replaced the line, MUCH better
EDIT: I remembered, ORIFICE TUBE
mykel37
Year and Model:
Post by mykel37 »
I discussed this issue happening on my S60 with a repair shop. They suggested "shimming" the compressor clutch. Volvo has a problem with the clutch engagement and this shim package fills that gap. They do this work for about $350.
mike
