Hey another ALBANY area person??? Keep an eye open for Volvo fests here or pm me if interested....BigSteve wrote: 26 Nov 2017, 09:51 This is caused by a loose ring at the end of axle shaft. Clean with wire brush. Glue ring with super glue. Reassemble. Or, replace axle.
STC light flashes when I turn...?
- Has thanked: 1613 times
- Been thanked: 4078 times
Zolll
- Year and Model: 2004 XC70
- Has thanked: 2 times
I also had the exact same problem. Diagnosis: Broken ABS ring on front passenger side - the ticking is the ring hitting the ABS sensor due to some binding during turns. Found an ABS ring on eBay for 10$. Remove axle, punch out the broken ring, bake the new ring in oven to expand it and slide it on a clean surface.
- 631 Views
Last post by bmdubya1198
- 13 Replies
- 5013 Views
- 1981 Views
Last post by Dieterly
- 1238 Views
Last post by Matty Moo
- 9 Replies
- 1317 Views
Last post by erikv11
