Checking out a 2005 V70 Base
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Re: Checking out a 2005 V70 Base
Jim -- I'm interested if you locate one.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
As far as I know all the cars are supposed to have it. Without it they don't work according to design anymore. That's why I questioned it. OP: Check that you really don't have one before looking for one. It's easy to spot. No sway bar - no swar bar links and those are clearly visible by just sticking you head to the ground behind the car.oragex wrote: ↑12 Dec 2017, 08:20My 2003 n/a has it (all rusty, by the way) but it's a S60. Perhaps the V70 n/a don't have it. I've heard the V70 have a sloppier drive. I'd surely install one if possible (if subframe holes already there, no interference with exhaust/suspension parts, etc). A used one with good bushings and two new end links should be decent, the bushings on the rear sway bar last much longer than on the front one.
A V70 has a bit more heavy glass in the rear and is a tiny bit longer than an S60 but the difference in drive should be small by design. However if a V70 has spent it's life hauling cargo and then you compare it to an S60 which probably hasn't there will probably be a noticeable difference.
- E Showell
Tack for det. Jag skall titta.
'95 855 auto (sold)
'95 855 auto (sold)
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 64 times
- Been thanked: 69 times
I must do that to my car AND I already have the bar.
1) Raise rear and let the wheels "full drop".
2) Remove rear shocks. You need them gone so you can squirrel the bar between the coils.
3) Fasten clamps to the body then add drop links.
That's it, right?
That's it, right?
- 850 LPT
- Year and Model: 96' 850
- Has thanked: 332 times
- Been thanked: 243 times
Still no photos of this beauty?
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
- E Showell
It has to be light out to take photos. I'm gone during daylight hours. Weekend. Promise.
'95 855 auto (sold)
'95 855 auto (sold)
- Has thanked: 1511 times
- Been thanked: 3829 times
Check out the wiring harness for the heated third seat...
- E Showell
Thanks, Steve. Pictures are from the Craigslist ad that drew me to the car in the first instance. Haven't had a chance to take any of my own. Tip of the hat to moderator abscate for posting.
'95 855 auto (sold)
'95 855 auto (sold)
- E Showell
Jim, a/k/a JRL, appears to be correct as far as rear sway bar goes. No evidence of same present.
'95 855 auto (sold)
'95 855 auto (sold)
It probably fell off and you drove by it. That's good, though, as you can't practice unless you pass the bar
- 1817 Views
Last post by SonicAdventure
- 17 Replies
- 4241 Views
