Heat and air weak at idle - 2004 Volvo XC90
My 2004 Volvo XC90 t6 the heat and air blows fine whe at consistent speed however when idling or just getting going it bogs down and doesn’t have the same strength
Reason: improved title, added tag
- jvl
- Year and Model: 2006 V70 2.4D
- Has thanked: 20 times
- Been thanked: 8 times
Does the blower itself bog down (blows air at same temp but not as powerful?)
Or is the blower consistent and does the temp lerature vary?
The first would indicate electrical trouble that arises at lower voltages (lower revs --> less alternator output). Could be a bad ground or corroded connection. Or dirty/faulty switch.
The latter would indicate a problem with coolant flow: thermostat stuck open, failing water pump, clogged cooling channels.
How is overall performance? Does the engine get up to temperature? How's the coolant level?
1999 V70XC - Sold at 250K miles
2006 V70 2.4D - bought at 190k miles and going strong
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
I would also think first electricals. Maybe check the controller on the blower
jvl wrote: 18 Dec 2017, 09:28 Does the blower itself bog down (blows air at same temp but not as powerful?)
- ggleavitt
- Year and Model: 06,08 XC90 V8
- Has thanked: 26 times
- Been thanked: 134 times
Original battery? If not, how old is it? (With Volvo part marked batteries, sometime you'll see the manufacture date in YYWW stamped on one of the terminals). My vote is on battery and/or alternator regulator until both can be omitted as causatives.
- oragex
Maybe the alternator doesn't charge well. I'd test the voltage at the alternator and battery. 8'd also check all pulleys on the serpentine belt for turning smoothly by hand with the belt off. Also the timing belt tensioner should not shake and it's needle should be correctly positioned
- 745 Views
Last post by cuhfs
- 576 Views
Last post by Flyingdutchman
- 1722 Views
Last post by EricGagnon
- 1844 Views
Last post by Hateprojects
- 23 Replies
- 4775 Views
Last post by DavidE7
