Heat and air weak at idle - 2004 Volvo XC90
crw4bama
Year and Model: 2004 xc90
Post by crw4bama »
My 2004 Volvo XC90 t6 the heat and air blows fine whe at consistent speed however when idling or just getting going it bogs down and doesn’t have the same strength
Reason: improved title, added tag
jvl
Year and Model: 2006 V70 2.4D
Has thanked: 20 times
Been thanked: 8 times
Post by jvl »
Does the blower itself bog down (blows air at same temp but not as powerful?)
Or is the blower consistent and does the temp lerature vary?
The first would indicate electrical trouble that arises at lower voltages (lower revs --> less alternator output). Could be a bad ground or corroded connection. Or dirty/faulty switch.
The latter would indicate a problem with coolant flow: thermostat stuck open, failing water pump, clogged cooling channels.
How is overall performance? Does the engine get up to temperature? How's the coolant level?
1999 V70XC - Sold at 250K miles
2006 V70 2.4D - bought at 190k miles and going strong
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
I would also think first electricals. Maybe check the controller on the blower
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
cabin filter plugged?
crw4bama
Post by crw4bama »
Same temp blowing but does idle rough has error code low air flow circuit
crw4bama
Post by crw4bama »
jvl wrote: 18 Dec 2017, 09:28 Does the blower itself bog down (blows air at same temp but not as powerful?)
crw4bama
Post by crw4bama »
Bogs down when rpm drops I do have check engine light on and it low airflow circuit a
ggleavitt
Year and Model: 06,08 XC90 V8
Has thanked: 26 times
Been thanked: 134 times
Post by ggleavitt »
Original battery? If not, how old is it? (With Volvo part marked batteries, sometime you'll see the manufacture date in YYWW stamped on one of the terminals). My vote is on battery and/or alternator regulator until both can be omitted as causatives.
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Tstat and heater core are the usual culprits. I posted some DIYs in forum.
oragex
Post by oragex »
Maybe the alternator doesn't charge well. I'd test the voltage at the alternator and battery. 8'd also check all pulleys on the serpentine belt for turning smoothly by hand with the belt off. Also the timing belt tensioner should not shake and it's needle should be correctly positioned
