It is unfortunate you are so far away, but contact me if you need help locally.
Rad Fan Turns On But Wont Crank Topic is solved
- Has thanked: 2200 times
- RickHaleParker
- Been thanked: 978 times
It would be good to know what was damaged. --Neil.
That might take awhile, he is probably busy exacting revenge ... run Mickey run!
Active
Past
Past
CadinVolvo11
- Year and Model: 1994 850 Turbo
I just thought that was a very plausible cause, If not I'm confident its the ECT sensor as they go quite a bit in the 850 models
Trickle chargers don't harm batteries. They are designed to do the opposite, to maintain the battery condition when batteries are not used in a long time. You don't need to disconnect the battery either.
A bad coolant temp sensor will not cause a slow turn over of the engine. It may cause it not to start though.
Clean all the engine grounds and check the battery +ve and -ve leads for corrosion of the cables and each of their connections are good. A bad ignition switch electrical portion may also cause this. Many years ago I have an old Volvo 122S that was a bear to start even with a new battery. I had to carry a spare battery and booster cables to get it started or bump start it. Couldn't figure out what the issue was as it ran fine otherwise. Eventually found a broken ground cable below the engine from the muffler to the frame. Replaced that and starting returned to normal.
- 1144 Views
Last post by wizechatmgr
- 1007 Views
Last post by lewiskoolman72
- 2519 Views
Last post by RickHaleParker
- 730 Views
Last post by whilst
- 937 Views
Last post by jenkinskg
