I have what may seem to be a very stupid question: How old is the battery?
EDIT: I also seem to recall an issue with the battery cables in these years.
05 s60 crank but no start
QUARKS40
- Year and Model: 2010 XC60
- Been thanked: 2 times
Re: 05 S60 crank but no start
2010 XC60 - P*, 3 Spoke steering wheel retro, Gearshift retro.
2001 S40 - 14T, BBTB, turbo back stainless DP, Upsolute, KW, 15mm rear sway, 17" Konig wheels, Custom Arctic Silver/Sonic Blue pearl paint, custom interior
allan4187
- Year and Model: 2005 s60, 2001 s80
Got the new part....So....in between waiting on the genuine (Denso) crank sensor...one day the car would start, another day it wouldn't. One day it started in the morning but not in the afternoon. it's driving me crazy. I finally got the new crank sensor in the mail and put it in. I tried the car before I put it in just to see. Nothing. I put it in. Still nothing. I reseated the wire, checked wires on the cam sensor. Nothing. Reseated the computer just for the hell of it. Still nothing.
I guess I'm sending it to an Indy shop....which I'm not looking forward to.
allan4187
I'll try that...thanks.abscate wrote: ↑08 Jan 2018, 01:49 You will get spurious cam and crank codes if the car sputters or misfires, I would look for root cause.
Plugs should be <30k miles, if you have been jump starting at all it's time to replace ignition coils that are > 100k miles, and finally test fuel pressure at the rail. This is all stuff to check before ECU
- Has thanked: 1502 times
- Been thanked: 3817 times
I'm tackling a spurious no start on my 2005 which is a a fuel delivery problem. Until you monitor the pressure at the rail, you don't know if the fuel delivery is correct, so rent the tool from AZ or sacrifice a pencil gauge.
With 0 pressure on the cranks and splutters but won't catch
allan4187
I got it to start after about 30 seconds of continuous cranking. I checked to pressure with a pencil gauge and got 40. After the first hard start it started fine several times the rest of the day. I cleared the codes and p0017 came back. (crank cam correlation)abscate wrote: ↑20 Jan 2018, 02:41 I'm tackling a spurious no start on my 2005 which is a a fuel delivery problem. Until you monitor the pressure at the rail, you don't know if the fuel delivery is correct, so rent the tool from AZ or sacrifice a pencil gauge.
40 is too low but that might be the gauge.
If it is running smoothly that code is indicative , if not smooth. Don't take it as gospel.
You don't get a traditional relay on a P2 fuel delivery system
The Central Electronic Module CEM sends requests to the PEM (or Fuel Pump Control Module) in the back of the car (fuel tank mount or inside spare tire, right side). There is a hard soldered relay in the CEM which is the supply voltage to the PEM (A16 on a V70 car - probably same on an S)
The failure points are the wiring to PEM, the PEM itself, and the fuel pumps.
shiretowndown
- Year and Model: 2005 XC70
- Has thanked: 5 times
Could you post that Walmart link again? The link above isn't working...chrism wrote: ↑07 Jan 2018, 19:25 I'd hang onto the OE sensors if you still have them.
"...sounds like I committed a mortal sin..."
Don't feel bad. I bought a $350 throttle body that didn't solve my problem - reseating the ECU into the connector fixed it. I think that's what I'd try if I was you. Hit the link below.
https://www.walmart.com/ip/Hardware-Too ... 3=&veh=sem
- 193 Views
Last post by JimBee
- 1621 Views
Last post by Littlelegs
