What is a good material to cut my own trunk mat?
jtp
Year and Model: 99 v70R
Has thanked: 11 times
Been thanked: 10 times
Post by jtp »
I keep putting off getting a trunk mat but I really should, I throw a lot of random stuff back there.
My last Wagon I had a weathertech mat and wasn’t impressed.
I use a tarp sometimes but it’s flimsy, anywhere I could get a sheet of some thicker rubber/plastic material for cheap?
99 V70R AWD
Almost 155K Miles
Breaking is how I know it’s working
98 S70NA (sold)
95 850 Turbo Wagon (RIP)
mrbrian200
Has thanked: 7 times
Been thanked: 84 times
Post by mrbrian200 »
Flooring/Carpet store
Been thanked: 4065 times
What was wrong with the weather tech?
Lowes sells rubber floor mat by the yard - that should do the trick for about 0.50 cents per SQFT
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
Oil-Dri Garage Guard Oil Absorbent Rugs.
Looks like carpet, absorbent on one side, impenetrable on the other side, cheap enough to to be sacrificial. On top of that, the gray color is close enough most people don't notice it ... if your trunk is gray.
Active
Past
jtp
Post by jtp »
abscate wrote: 12 Feb 2018, 06:41 What was wrong with the weather tech?
Ya that would be perfect, gonna go take a look. With my weather tech mat the material was too thin to handle the way they designed it with the 2-3” raised edge all around. The edges just start to curl and take away from the custom fitted look you’re paying a hundred plus for.
If you’re gonna do raised edges I think it’s gotta be harder thicker plastic like some of the late model Volvo trunk mats out there.
In fairness I used it a lot and had it in and out of the car (my kids are still small enough that they think riding in a rear facing third row is a special treat).
At this point I just want something that fits well and I can beat up and then replace every so often at a reasonable price.
99 V70R AWD
Almost 155K Miles
98 S70NA (sold)
WhatAmIDoing
Year and Model: 1998 S/V70 T5M
Has thanked: 104 times
Been thanked: 105 times
Post by WhatAmIDoing »
I saw a wagon with a Volvo silicon rubber cargo mat once. Looked really good. Don't want to think how much that cost, but seemed really durable. For something cheap and protective that will soak up spills, I just use cardboard.
'98 S70 T5M - 323,000mi - awaiting heart transplant :shock:
'99 S70 "AWD" - 220,000+mi - gone :cry:
Knows enough to be dangerous :wink:
skloon
Year and Model: 94 850 95 850 04 S60
Post by skloon »
I just grab some of the factory ones from picknpull- the sedan ones will fit a wagon just have a couple of bare areas up at the front corners
jtp
Post by jtp »
skloon wrote: 13 Feb 2018, 09:53 I just grab some of the factory ones from picknpull- the sedan ones will fit a wagon just have a couple of bare areas up at the front corners
The Sedan mats are still available new I think. From the diagrams it looked like they’d fit like that but it’s good to know that’s the case.
Seems weird they discontinued the factory trunk mats for wagons. Much larger market than most of the parts still in production, why not make that money?
99 V70R AWD
Almost 155K Miles
98 S70NA (sold)
smoggyama
Year and Model: 1996 850 turbo
Been thanked: 3 times
Post by smoggyama »
I have used a discarded Persian style rug after cleaning it at the car wash, industrial carpet, and currently am using a custom fit cardboard with a uhaul furniture blanket, cut and taped underneath. I'm into low weight and sound absorption, no cost repurposing. or go spend your kids tuition at the dealership.
Life is like a box of chocol- make that an engine compartment. You never know where the tubes go or how to rout a belt 'less you read the diagram on the underside of the hood. Do it right the 2nd time. So when all else fails, READ THE INSTRUCTIONS.
Be good do good feel good live good.
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
Stall mats for horses - can be sourced at tractor supply. ~$40-$60 and the mat will last the life of the car. You may want to air it out a couple weeks before cutting and installing...
