Did you know? 🤔
Water in Gas
Help, Advice, Owners' Discussion and DIY Tutorials on the Volvo S80 model. Sometimes called an "executive car", the S80 was and continues to be Volvo's top-of-the-line passenger car.
sucanache
Year and Model: 2008
Has thanked: 10 times
Been thanked: 0
United States of America
sucanache
Water in Gas
Post by sucanache » Wed Feb 14, 2018 10:02 am
My 08 S80 quit - would try to crank and sometimes would but then would bog down and die. Codes read multiple cylinder misfire. Took fuel rail off and liquid poured out, part of which evaporated like normal gas and clear "bubbles" of liquid remained. I am thinking water. Blew out rail and reinstalled. Will crank and run with some misses. Will products like Heet clear this up? Our temps have been from single digets to very humid mid 60's so I am thinking condensation.
Rattnalle
Has thanked: 20 times
Been thanked: 123 times
Sweden
Rattnalle
Re: Water in Gas
Post by Rattnalle » Wed Feb 14, 2018 12:56 pm
Adding ethanol in some way will probably get rid of it in a less noticeable way than the current one. It'll mix evenly with the ethanol and burn without making a fuss. If you have access to petrol that's part ethanol a few litres of that will do the trick.
These users thanked the author Rattnalle for the post:
sucanache
sucanache
Been thanked: 0
sucanache
Re: Water in Gas
Post by sucanache » Thu Feb 15, 2018 4:40 pm
Thank you!
crlande
Year and Model: 240DL;850;S70
Has thanked: 1 time
Been thanked: 20 times
crlande
Re: Water in Gas
Post by crlande » Thu Feb 15, 2018 6:00 pm
Ethanol (E10) blended gas at the pumps is the problem. Ethanol attracts water so if your tank is less than full you have moist air in rest of tank space.
These users thanked the author crlande for the post:
sucanache
Rattnalle
Sweden
Rattnalle
Re: Water in Gas
Post by Rattnalle » Thu Feb 15, 2018 10:38 pm
Condensation will form either way to some degree. Less if the tank is kept mostly full. But water and ethanol is soluble so the water can go somewhere in a controlled fashion a little at a time.
But sure it means there can be water in the stuff to begin with as well since it will be mixed with condensation from tanks along the way as well.
Over here I barely think they sell gas with less than 5% ethanol except for boats and stuff where it might be sitting in a tank for months unused.
sucanache
mrbrian200
Has thanked: 7 times
Been thanked: 80 times
mrbrian200
Re: Water in Gas
Post by mrbrian200 » Fri Feb 16, 2018 7:29 am
How do vehicles that run on E85 deal with this problem?
I've seen water in my fuel filter-- one time last summer I disconnected and poured the contents of the filter into a glass jar. From the amount of water observed in the bottom of the jar it would seem that the bottom half of the filter below the inlet/outlet was full of water. For all I know, the bottom half of the filter is normally full of water 365.
These users thanked the author mrbrian200 for the post:
sucanache
June
Year and Model: 2004 S80 T6
Has thanked: 256 times
Been thanked: 139 times
June
Re: Water in Gas
Post by June » Fri Feb 16, 2018 8:10 am
I understand ethanol absorbs the water allowing it to pass. I do know acetone mixed with water alone will run a car engine no gasoline. I saw it on a tv program. On Coast to Coast radio program a good 15 years ago a guest stated that by adding a small amount af acetone to each tank will boost fuel economy, keep system cleaner, and remove moisture from tank. You may want to do a Google search about acetone added to gas. June
These users thanked the author June for the post:
sucanache
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
sucanache
Been thanked: 0
sucanache
Re: Water in Gas
Post by sucanache » Mon Feb 19, 2018 5:49 am
After taking off the fuel rail and dumping the water, etc. out, I reinstalled it and the car ran ok for a few minutes, with some misses, Now back to the same as it was. I have added a can of Heet. Planning to repeat the removal, dump process today. any suggestions beyond that? Can I take the rail off, put tubing on the gas line and use the fuel pump to pump some of the contaminated gas out of the lines/tank?
Rattnalle
Sweden
Rattnalle
Re: Water in Gas
Post by Rattnalle » Mon Feb 19, 2018 6:56 am
The pump will do it for you if you just turn the ignition to 2 and put a tube in a good place, yes.
Heet seems to be mostly expensive methanol which does the same thing as adding ethanol. But if you have a lot of water, enough to make the var run poorly, I'm guessing you'd need a lot more to really make a difference.
sucanache
sucanache
Been thanked: 0
sucanache
Re: Water in Gas
Post by sucanache » Mon Feb 19, 2018 7:02 am
Thank you!
