1996 850 GLT No crank no start
cxf
Year and Model: 1996 850T
Post by cxf »
Hi, 1996 850 turbo. Car started and ran fine on my way home last night. Today I got in to go to work and the car started and ran but had a different sound while starting but sounded normal when running. I shut it off and tried to start again and no crank. Battery is only a few months old and shows 12.45 v on my meter. I put the charger on it anyway for about an hour and the car will still not crank. Searched on here for starter relay but apparently the 850 hasn't got one. Any ideas while I search archives will be appreciated. Thx
cxf
Post by cxf »
Sorry title should read "No crank no start"
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Failed starter or bendix.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
kahl
Year and Model: 2000V70XC
Been thanked: 10 times
Post by kahl »
Plus on what Misha said....but check the connection of the tickler wire on the bendix.
Has thanked: 1614 times
Been thanked: 4078 times
Welcome cxf
Search starter bypass location to find the thread showing you how to bypass the key and relay for the starter circuit and test the starter directly
viewtopic.php?f=1&t=78989&p=448135&hili ... ss#p448135
cxf
Post by cxf »
Thank you all for the welcome! I have been a member here for quite a while but don't post much although i do get email notifications. I will definitely get on this tomorrow... i think I have a remote start gizmo out in the garage. I really appreciate your taking the time to share your knowledge.
Remember that bypass is just that, it’s also bypassing the park, brake, and clutch safety interlocks
Once you put 12 voltson thatvconnector, it’s turning the engine over.
A sudden complete loss of cranking with a good battery is often ignition switch , electrical part
cxf
Post by cxf »
Update: I found the bypass lead but not my remote starter. I had a heavier gauge wire that I connected to the bypass and then touched to the + battery post and got nothing. Looks like the starter is toast... kinda makes sense because when it did start yesterday it did sound a bit weird before it started and then after i shut it down it wouldn't crank again.
WhatAmIDoing
Year and Model: 1998 S/V70 T5M
Has thanked: 104 times
Been thanked: 105 times
Post by WhatAmIDoing »
Try hitting the starter with a broom handle or crowbar while someone cranks. Old trick that sometimes works. Before though, make sure power is actually getting to the starter.
'98 S70 T5M - 323,000mi - awaiting heart transplant :shock:
'99 S70 "AWD" - 220,000+mi - gone :cry:
Knows enough to be dangerous :wink:
cxf
Post by cxf »
Already have done the broomstick thing... actually a heavy wooden dowel. Thanks
