Alignment after shocks
woodycaldercloggs
Year and Model: v70 1998
Has thanked: 23 times
Post by woodycaldercloggs »
I have a 1998 volvo V70.
If I change the Front Shocks ONLY - can anyone tell me if you definitely need an alignment.
I have heard conflicting stories on this.
The alignment center would probably say yes - but can you'd expect them to say that :? :? .
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
You should not need it, unless the shocks will change the ride height or if the control arms are worn.
You may want to look to the spring seats as well (go only with Sachs)
Rattnalle
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
It's not so much the new shocks as the fact that you're taking everything apart. There are several places with some possibility of adjustment that you'd need to be very sure they're back in the same place. Both at the top of the strut and the bottom.
An alignment is cheaper than new tyres. At least if you run good tyres ;-)
misha
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
No allignment is needed unless you disturb tie rods.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 73 times
Post by FlyingVolvo »
I would. Strut only shouldn't mess with the toe in/out, but it will likely mess with the camber when you reattach the hub/brake assembly. Not as big of a deal as the toe, so you can maybe get away with not doing it.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
misha
Post by misha »
These cars have fixed camber and it's not adjustable.
On some cars it's adjustable,but on these cars it's not.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 1502 times
Been thanked: 3817 times
Simply put the new shocks on, then monitor your tire wear. Make sure you report back when you see it is normal without alignment
Has thanked: 292 times
Been thanked: 765 times
Shouldn't need it. You can usually get it checked for free, though to be fair I never do that ...
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
WhatAmIDoing
Year and Model: 1998 S/V70 T5M
Has thanked: 104 times
Been thanked: 105 times
Post by WhatAmIDoing »
misha wrote: 14 Apr 2018, 05:01 These cars have fixed camber and it's not adjustable.
Really? Because every alignment shop I've been to says they adjusted the camber. They also say the rear-end alignment is non-adjustable.
'98 S70 T5M - 323,000mi - awaiting heart transplant :shock:
'99 S70 "AWD" - 220,000+mi - gone :cry:
Knows enough to be dangerous :wink:
misha
Post by misha »
Yes really...change the allignment shop.
I wouldn't go back to them again.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
