My 2000 volvo s70 randomly dies while drving or idling
Ive been having this lady for a while now. My volvo will just lose power and die on the side of the road with no warning. Sometimes it will start right back up and other tines it won't. It could go days between episode as well. I have replaced the tps, alternator, mass air flow sensor, cleaned the vvt solenoid, as well as getting my oil changed and putting a seafoam treatment into it.
- Been thanked: 4063 times
Usually this Is a fuel pump issue, with fuel pressure being the diagnostic to watch via OBD while driving
- Has thanked: 2196 times
- Been thanked: 1850 times
Did you replace the Fuel pump relay?
Is this a turbo or non-turbo?
What brand of fuel pump did you use?
Have you replaced the fuel filter?
You need to pull the fuel pump relay and inspect the terminals for discoloration and burning. Its pretty common on these cars. You can make a jumper wire that you can swap in next time it stalls and won't restart. A relay that is failing might be giving you less fuel pump voltage than usual which will show up as low fuel pressure measured at the rail.
The other much rare possibility is an interruption to the coils (5 of them) 12 V DC power. They all receive 12 V from a common relay, and are fired by the ECU grounding them at the right time.
You need to measure it when the failure occurs, of course. Either a gauge in the trunk or a data logger via OBDDuffpool wrote: 25 May 2018, 06:30 Ive got good fuel pressure and am not sure if the relay was changed when the fuel pump was. It is also non turbo
We have had a rash of people putting in both OEM and aftermarket pumps and buggering up the fuel feed lines on install - only one ugly way to look for that - a do-over.
- stargate476
- Year and Model: 2000 volvo s70
- Has thanked: 2 times
I just had a similar issue with my car, replaced fuel pump, filter, every so often it was still cutting off, ended up being the fuel pump relay. They are prone failure
- lext
- Year and Model: 1994 854
Same here, fuel pump relay. That should be the first thing you replace if you experience this symptoms. Only when that doesn't help then you start changing something else.
I also carry a jumper with me all the time. You can jump the contacts and drive around until you get the replacement relay (if the jumper does indeed stop the random dying).
94 850 non-turbo
2011 S40 T5
2011 S40 T5
- 993 Views
Last post by virginiavolvolover
- 464 Views
Last post by Celovnik
- 15 Replies
- 4067 Views
Last post by shaker_chi
- 1802 Views
Last post by TRuck
- 20 Replies
- 3003 Views
Last post by 850 LPT
