are there no aftermarket replacement fog lights for 2007 v70 2.5t?
starboard
Year and Model: 2007 v70 2.5t
Post by starboard »
I'd like to buff up my 2007 v70 2.5t (142k miles) with some new fog light lenses. I understand the fog light is a single unit and I can't just replace the lenses. The problem is I can't find any aftermarket (e.g. TYC) fog lights for this car. The only parts I find in the U.S. are Genuine Volvo and a tad pricey. (skandix.de appears to have something, but the 50 euro shipping charge to the U.S. is prohibitive)
Left: part nbr: 8693347 (~$118 at Tasca parts, $180 retail)
Right: part nbr: 8693348
Is this fog light design too rare/limited for anyone to make an aftermarket part?
Thanks for your help.
--- current:
2007 V70 2.5t FWD / 142k miles
2006 XC90 2.5t FWD / 73k miles
--- gone but not forgotten:
1996 855 turbo
1995 855 na
1988 740
1985 245 dl
1983 244 gl
2007 v70 fwd 2.5t
2006 xc90 fwd 2.5t
MDK
Year and Model: 2004 S60R
Been thanked: 42 times
Post by MDK »
The 70 and the 60 share the same fog lights unless it's an R edition... if they are cracked .. scrapyard.i...f sandblasted... try putting some sand into some turtle wax with screw gun and buffing pad attached...buff till clear ( if they're glass of course)
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
MDK wrote: 03 May 2018, 19:46 The 70 and the 60 share the same fog lights unless it's an R edition... if they are cracked .. scrapyard.i...f sandblasted... try putting some sand into some turtle wax with screw gun and buffing pad attached...buff till clear ( if they're glass of course)
maguires machine polish is good too.
Sand would seem very aggressive.
mrbrian200
Has thanked: 7 times
Been thanked: 84 times
Post by mrbrian200 »
These lenses are plastic. I wouldn't use sand.
MDK
Post by MDK »
MDK here... sorry guys I didn't realize the newer ones were plastic... I would never intentionally post something misleading. I paint so... they're are varing degrees of " sand". .. just a little goes along way when added to wax and the glass gets foggy. The macQuier lens restore did a great job on the rear taillights of my xc70 ... take care
cbpitt01
Year and Model: 2006 V70 2.5T
Has thanked: 6 times
Been thanked: 4 times
Post by cbpitt01 »
Check out this item on eBay: 122886767542 (copy and paste). $99 shipped.
2006 V70 2.5T, Ice White with Arena/Oak, bought “newsed” @ 183,500 miles in Dec 2015; 244,000+ as of 12/23/2020.
packetfire
Year and Model: 2010 v50 2.4i
Has thanked: 17 times
Been thanked: 30 times
Post by packetfire »
I'm confused... the fog lights changed in 2005?
So 2004 and earlier are different?
Or can parts interchange between 2004 and 2005+ ?
1982 240DL: Drove it 32 years and 1.5 million miles (sold, even still had mint leather!)
2001 v70 2.4T: The most expensive $1500 car I ever bought ("Volvo Turbo" - what an oxymoron!) (sold)
2004 v70: Far less fatally-flawed v70 - It served well (sold)
2010 v50: Smaller, slightly sportier wagon. Its got a spoiler, so I upgraded with sway bars!
mrbrian200
'04 and before are different style foglights, and the 'R' models are different from non 'R' as well. I had a hell of a time tracking down a used one for my car (on the cheap). The RH side reflector was broken when I bought it, which is typical because there isn't enough clearance between the back of the fog and the washer fluid reservoir. If you bump anything down low on the right side, such as a parking stop/curb, the back of the fog gets pushed back and damaged. There was a right angle plug used on some of the XC models to increase this clearance (and prevent parking damage to the RH fog assembly). Why on earth Volvo didn't use it on all of them is real a head scratcher.
The PN for the right angle plug is 30795071
You only need one for the RH side. The left side has clearance and doesn't get broken. If you're going to go through the trouble of replacing the RH fog, there's little point to it unless you also get the right angle socket/plug. It'll eventually just get broken again if you don't. Either you'll misjudge how close you are to a parking stop, or somebody else you let drive the car will do it.
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
I have fixed broken fog light lenses on my old 2001 and 2002 XC70 by removing the cracked glass and replacing it with clear plexiglass and then sealing it shut with silicon. One lasted a year and a half without issues, at which point I parted ways with the car. I assume it still works. The other one my brother drives and it is still going strong.
The only issue is the glass is curved and off the shelf plexiglass is flat. If you look at it carefully you can tell, but the fix was time only as I had the parts laying around. Most people cannot tell - and repaired looks a ton better than broken.
Process is straight forward - remove glass and clean up glue - trace shape onto plexiglass and cut and sand to size, then reseal.
Just an option.
