Question:
YOu were able to take the dash out one of the doors...I'm wondering if one could also take it out the back tailgate also then? turn it the long way? maybe? no? yes?
1999 V70T5M56 AC evap 9171781 and heater core 9144221 replacement (Pics end of thread)
Re: 1999 V70 T5 AC evap and heater core replacement
98’ S70 T5 Turbo Manual - Midnight
01' S60 T5 Turbo- Brandy
98' V70 T5 Turbo - Swifty
93’ 244 n/a - Mr.Chill
91' 940 SE Turbo - Mojo SOLD
83' 242 DL - Bluto SOLD
93' 940 Wagon - Django - SOLD
- Year and Model: Lots
- Been thanked: 128 times
You won't get it past the back seat if you do it that way. I took mine out of the passenger door with good clearance and with the help of the other (more delicate) hands in the household.98T5 wrote:Question:
- Has thanked: 1500 times
- Been thanked: 3812 times
Would definitely recommend one helper on passenger end of dash, and removal out the driver door.
Here is a look at the Electronic Climate Control removed from the car, annotated.
Note the large pin which you need to wiggle free of the dash on driver side.
Old thread alert
I have a massive pic database from this project so checking with Matt to see how best to handle.
Might just link to drop box or like, tbd.
[attachment=15]VOLVO AC EVAP APR 2013 - 2 (3).jpg[/attachment]]]]]t]]]]]]]]]]]]]t]]]]]]]]
- sleddriver
- Year and Model: 1998 V70 T5
- Has thanked: 11 times
- Been thanked: 12 times
Wow...what a mess. Amazing how cars rust up North.
Thanks for the pics.
M1 10W-30 HM
M1 10W-30 HM
brunocerous
- Has thanked: 284 times
- Been thanked: 36 times
Amazing job and pictures! My brother is gearing up to do this job, too.
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
- theWIFES_S70
- Has thanked: 61 times
Hahaha, yeah, I would have attempted this except that, you know, my brother dumped a VR6 timing chain job in my lap...
Bravo, abscate! I love the documentation. I'm inspired!! I'm wondering though, how many hard lines should I replace prematurely... Did you replace Volvo 9171406? https://www.fcpeuro.com/products/volvo- ... pe-9137406
These hard lines are pricey!
Retired:
2015 Volvo S60, T5, 85K
I replaced that one and also the drier to condenser return line due to corrosion
There are three fasteners that separate you from Nirvana on this job.
The two 6 mm hex screws that hold the hardline behind the right head light..you can see the mess I made when one of the captive fasteners broke
The hex holding the suction line into the compressor. This is the one I got to with the long extension
Once those three are out, all of the hard connections can be dealt with on the bench and not on the car. The drier connections are big , 27mm (1 1/16”)+ nuts which will be locked tight and there is no clearance on car to snarf these off.
Up top, you can heat and apply pure torque , all is good.
Separating the trombones from the hard lines is also easy out on the bench
Replacing the orfice tube in place looks doable with another high pain factor. Look at the clearance for the 19 and 22 mm open end, and you don’t get pure torque with these. Crows feet probably required, and careful wrenching, or get it on the bench and 15 seconds. Not sure how you are going to keep things clean there either
Hours of hard wrenching and knucklebusting turn into minutes
