96 850 o2 sensor
- Danonly55
- Year and Model: 1996 850 sedan
- Has thanked: 23 times
- Been thanked: 4 times
96 850 o2 sensor
I replaced my up stream o2 sensor a month ago and It has thrown the same code twice in the last week. Is there anything else that could cause this ?
2014 Ford 3.5L ecoboost XLT
1995 Volvo 850 wagon GLE
Life is tough, but it's tougher when your stupid'
" John Wayne
" John Wayne
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 126 times
My feeling would be an fuel/ignition/leak type issue.
- RickHaleParker
- Been thanked: 958 times
What is the code?
There are lots of thing that can cause O2 and catalytic efficiency codes when the O2 and catalytic converter are in working order. Wizechatmgr outlined them, something messing up the fuel/air ratio or preventing fuel from burning efficiently.
- Has thanked: 293 times
- Been thanked: 765 times
If you installed the universal type sensor (even from Bosch), people have had a lot of problems with those. You need the pre-wired, genuine Bosch sensor. Similarly, this part is known to be counterfeited frequently on the eBay market.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- misha
- Has thanked: 152 times
- Been thanked: 402 times
1st o2 sensor(upstream) can't throw cat efficiency code...that's the 2nd o2 task(downstream).RickHaleParker wrote: ↑10 Aug 2018, 23:46 What is the code?
@ Danonly55....vacuum leak,exhaust manifold leak or even a tiny crack in flexi pipe between cat & exhaust manifold could cause the front o2 sensor code...dirty maf too...because the oxygene which Maf metered doesn't correspond with oxygene that o2 metered because one of those sensors are dirty.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Danonly55
I purchased the Bosch sensor from IPD, 120$ Im thinking its a fuel burning issue, I bought the car at auction a few months ago and have not checked the plugs or distributor. You guys confirmed my thoughts. Thanks Guys. Any recommendations on plug type ?
" John Wayne
" John Wayne
- misha
Cheap copper ones single prong NGK or BOSCH properly gapped...or original triple prong Volvo plugs.
Cap & rotor must be Bosch.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
What misha said!
'06 S60 R, 197k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- RickHaleParker
P0133 can be:
EFI-435 Front heated oxygen sensor (HO2S). Too slow
or
EFI-436 Rear heated oxygen sensor (HO2S). Compensation
EFI-435 Possible sources
uneven compression
air leakage in the intake system
air leakage in the exhaust system
faulty fuel pressure
defective front heated oxygen sensor (HO2S).
EFI-436 Possible sources
uneven compression
defective rear heated oxygen sensor (HO2S)
or
uneven compression
uneven compression
