- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
Got home from the hospital and wanted to cry... see classsifieds
Current Volvos:
- Has thanked: 316 times
- Been thanked: 531 times
Good luck with the sale, sounds like a great car! I hope all is well!
The plug for the switch? It should be the one directly to the right of the headlight knob.
sventastic
- Year and Model: 1996 854R
- Been thanked: 6 times
Thank you! The new orbital polisher has already paid for itself I think!
1996 854R | M56H | 16T | 274k | BC, Canada
- FLXC90
You have thw GLT and the R, round out the set? 16T for the GLT, 18t for the T5 plus your your rbmdubya1198 wrote: 27 Aug 2018, 17:44Good luck with the sale, sounds like a great car! I hope all is well!
Current Volvos:
Haha, if I could afford to buy another car I would! I'm currently trying to unload the 740 to fund finishing up the R.FLXC90 wrote: 28 Aug 2018, 13:38 You have thw GLT and the R, round out the set? 16T for the GLT, 18t for the T5 plus your your r
- RickHaleParker
- Been thanked: 979 times
Turned a $500.00 Mechanics Special, a 2003 S40 with 110,000 miles, into a running car with $130.00 worth of parts and a $145.00 tow. Slipped timing belt, it slipped just enough to create a crank but no start condition but, no interference damage.
Root cause. the tab on the tensioner broke and the tensioner moved .. this is why one should check the timing belt tension periodically. Snapped belts are not the only thing that can go wrong. Catching a problem early can save a engine.
Active
Past
Past
Wow, you lucked out big time! Well done!
