This is the best view I could get without taking anything apart. Using my iPhone in video mode with LED illumination, holding my hand in the vicinity of the intercooler-to-throttle tube and starter. You can sort of partially see the metallic sleeve around the lower hose from the breather box to the block, but the starter is blocking most of that view.
It seems like everything is oily, so I'm not sure if this is helpful in pinpointing anything.
[2001 V70 2.4T] Oil leak, intake side, lower engine / oil pan
- prwood
- Year and Model: 2001 V70 2.4T
- Has thanked: 9 times
- Been thanked: 22 times
Cars I've owned:
- Been thanked: 4071 times
Really oily up top but not enough for flow.
Crack in th ebottom of the box, maybe?
Really wet on that knock sensor....
- prwood
I just ordered a borescope, so I should be able to take a look this weekend without tearing things apart.
Cars I've owned:
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
Did you order the type that connects to your cell phone? I'd be interested in knowing how well those work.prwood wrote: 13 Sep 2018, 06:12 I just ordered a borescope, so I should be able to take a look this weekend without tearing things apart.
- prwood
I did. From what I gather, the hardware on these is okay, but the viewer apps are junk, but if you set everything up in the right order it's supposed to work ok.
Cars I've owned:
- prwood
Okay. The endoscope wasn’t super helpful. I tried getting photos with both my phone and the endoscope after cleaning things up under the intake manifold. Frankly, the endoscope pictures aren’t worth posting. Anyway, here’s a phone photo from before the cleanup and then one from after cleanup and driving around for a while.
It looks to me like the leak is coming from the top connection between the engine block and the breather box. You can see what looks like fresh oil underneath the hose.
Cars I've owned:
Definitely a leak there ( maybe clamp has cut hose?) but there is oilabove that too, maybe more than one leak?
