'99 V70, FWD, non-turbo, base -- fistful of codes and no start Topic is solved
Year and Model: Lots
Been thanked: 128 times
Re: '99 V70, FWD, non-turbo, base -- fistful of codes and no start
Post by precopster »
Firmware level determines if you get limp mode or not; that was part of Volvo's "fix" in 2006
Has thanked: 1498 times
Been thanked: 3810 times
E Showell wrote: 29 Sep 2018, 17:16 On the PNP?
No, on the ETM. The horrible fix was to allow more errors between the two sensors before the ECU gave up and forced limp mode. That got Volvo out of a lot of warranty repair by pushing it to 10 years before you got limp
I can't really complain - mine made it to 130k, which is several sets of caps/rotors/ playing with IAC,
Ive got 90k on the replacement yellow ETM.
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 111 times
Post by E Showell »
I have a Xemodex rebuild. Thought I was good to go.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
E Showell
Post by E Showell »
I think root cause was bad fuel pump relay. It has been replaced and I will monitor.
'95 855 auto (sold)
Five years later and I’m still driving this beautiful car, the Shagg Wagon
The ETS light comes on when the brake position sensor on the power brake booster faults, I have a spare in the glove box but it rears its head about twice a year
I had the exactly the same crank, no start due to low battery last week.
Shagg just got a a nice new valve job with stem seals in June!
E Showell
Post by E Showell »
It helps to do a good job picking the new owner.
'95 855 auto (sold)
Caitlin appreciates that
