knocking from frontwheel s60
mickwoolley
- Year and Model: 03 s60
Sounds like a CV joint. But it doesn't get better or worse when you turn left or right,start or stop,just comes and goes
- SuperHerman
- Been thanked: 207 times
Did you look at the tires for any damage or maybe an embedded foreign object?
Try rotating tires from front to back and see what happens.
velorider
- Year and Model: 2005 S60 T5
- Has thanked: 2 times
- Been thanked: 27 times
Very common sources of knock on S60 are the suspension components. Here the my suggestions to check in order:
* End Links: Grab the end links and rotate to test for play, push up and down to test for play
* Torn front bushing of control arms: Grab the wheel at 3 and 9 and wiggle checking for play in the front bushings
* Outer tie rod: Grab the wheel at 3 and 9 and wiggle to test for play
Good luck
Good luck
mickwoolley
Thanks guys will check all those.let you know what I find.
- 9 Replies
- 7117 Views
Last post by dacson
- 1174 Views
Last post by Mischiefmerle
- 2116 Views
Last post by 2002V70XC
- 992 Views
Last post by Eddienorgard
- 25 Replies
- 4208 Views
Last post by dosbricks
