knocking from frontwheel s60
mickwoolley
Year and Model: 03 s60
Post by mickwoolley »
Sounds like a CV joint. But it doesn't get better or worse when you turn left or right,start or stop,just comes and goes
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
Did you look at the tires for any damage or maybe an embedded foreign object?
Try rotating tires from front to back and see what happens.
velorider
Year and Model: 2005 S60 T5
Has thanked: 2 times
Been thanked: 27 times
Post by velorider »
Very common sources of knock on S60 are the suspension components. Here the my suggestions to check in order:
* End Links: Grab the end links and rotate to test for play, push up and down to test for play
* Torn front bushing of control arms: Grab the wheel at 3 and 9 and wiggle checking for play in the front bushings
* Outer tie rod: Grab the wheel at 3 and 9 and wiggle to test for play
Good luck
mickwoolley
Thanks guys will check all those.let you know what I find.
