I can't remember the particular yard, but I do recall hauling 2 alloys back to the wreck when the guy at the gate told me alloys with tires were $160... each. Valuable lesson: always check the prices of the items you want before you pull them.erikv11 wrote: ↑18 Oct 2018, 09:36That's funny, it never occurred to ma some yards wouldn't sell them, and I've never seen steel wheels that cheap. But I don't go to a lot of different yards - interesting to hear your experience. When I say cheap I am considering that you don't pay much more for an alloy than a steel, and the number OP threw out there ($150) for a spare.WhatAmIDoing wrote: ↑18 Oct 2018, 09:04 ...What junkyards are you going to? Every junkyard I've ever been to either doesn't sell rims/tires, and I've never seen a yard sell alloy rims for less than $100 if you can find any there. However, I can get a set of 4 steel rims for $40 at the local salvage yard.erikv11 wrote: ↑17 Oct 2018, 18:10 Also consider that alloy rims are also cheap at the junkyard and much lighter than steel ones. Easier to stow. Get one with a reasonably new tire on it. Inflate it to 40 psi and put it in the spare tire well. In 2 years when you think to check it again, it will be at something like 25-30 psi. And some 30x safer than a donut spare every day of those 2 years.
$21 for steel wheel with tire, $36 for alloy with tire (Or $21 if you can swap them a bent alloy as core ...), and I always see Volvos with alloy wheels when roaming this regionally popular yard: https://www.upullrparts.com/part-pricin ... c94c9-0c8e.
jack stowage - how does it work?
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
Re: jack stowage - how does it work?
Knows enough to be dangerous
- Has thanked: 292 times
- Been thanked: 765 times
WhatAmIDoing wrote: ↑18 Oct 2018, 09:48 ... I can't remember the particular yard, but I do recall hauling 2 alloys back to the wreck when the guy at the gate told me alloys with tires were $160... each. ...
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
850forum
- Year and Model: 1995 850 turbo wagon
- Been thanked: 6 times
I got my wheel specs here. I have 16" wheels:misha wrote: ↑18 Oct 2018, 04:24 5x108 ET 35-49 6-6.5J CB 65.1
All big Volvos use the same bolt pattern.
Newer ones too but have higher ET...and as long as you stay up to ET 49 it is ok....ET 50 and higher will not fit.
That said....p2 models can use all p80 rims but p80 can't use p2 rims in some cases.
http://www.wheelfitment.eu/car/Volvo.html
Maybe the tires are too old(DOT#) and can't hold the pressure,valves are not sealing to the rim properly or rims are bent and leaking pressure.
I didn't seen the good rim leaking pressure YET.
https://www.wheel-size.com/size/volvo/8 ... t-eudm-223
Volvo 850 1996 2.3T
– Generation: P80 [1991 .. 1997] [EUDM]
– Power: 223 hp | 166 kW | 226 PS
– Engine: l5, Petrol
– Center Bore: 65.1 mm
– Wheel Fasteners: Lug bolts
– Thread Size: M12 x 1.75
– Trim Production: [1994 .. 1997]
Tire
Rim
PCD
205/55R15 88V
6.5Jx15 ET43
5x108
2.3 / 2.1
205/50R16 87V
6.5Jx16 ET43
5x108
2.3 / 2.1
205/45ZR17 85W
7Jx17 ET40
5x108
2.5 / 2.3
NEVER OPEN THE HOOD !!!
- misha
- Has thanked: 152 times
- Been thanked: 402 times
I have 16" Persus wheels from the factory.
Factory size was 205/50/16 but Volvo switched to 55 profile because owners were complaining about bent rims with 50 profile.
All big Volvo's rims are interchangeable..some have ET 35...some 43...some 49.
As long as you stay UP TO 49 you'll be fine.
I have 2002 S80 alloy rims for my winter tyres 205/55/16 and they have ET 49 and they are 7J.
5x108
ET 35-49
CB 65.1
6-7J
5x108
ET 35-49
CB 65.1
6-7J
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
850forum
Previously I found a rim swap calculator that went into the E number... complicated.
But I would need at least both rear or both front to have the SAME number, would I not?
Or don't you think it would matter for a spare that won't be driven too much?
But the idea of a full size spare is to proceed at full highway speed & have the ABS work correctly etc.
15 inch wheel with a tire that overall comes close to the diameter you actually have mounted would be fine for a spare. For me the idea is to be able to travel several hundred highway miles safely, so a slight diameter mismatch will not be a problem if you can't match it exactly. My P80 cars all have 195-60-15 spares, even the 95 R with 205-55-16s on it. That's a 2.9% difference in diameter which is minimal.
In fact I've never tried to put anything bigger than a 195-60-15 in the spare tire well, those 16s may not fit as they are wider too.
Many web sites will compare diameters (e.g. https://tiresize.com/comparison/). What size are the actual tires on your car now?
'06 S60 R, 197k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
That is almost identical diameter to 195-60-15, which are abundant and fit in the spare well. So that's an option anyway, though I understand you may not want to go that route.
'06 S60 R, 197k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
