Just replaced the seat release buttons on my 1996 855.
These red buttons starts to break after 15-20 years of use, typically the front ones, as they get the most use.
Didn't find a thread that describes the procedure, so here it is:
You can get replacement buttons from IPD
https://www.ipdusa.com/products/5513/11 ... cle-button
Or you can get them easily from a junkyard, the back seat buttons are identical to the front seats, and often do no see a lot of use, especially on sedans.
The buttons are held in place by a tab on each side and can be popped out with a small, flat screwdriver.
To release, push a screwdriver tip between the button and the black holder, and then twist the tab a bit outward, until it is released, repeat on other side.
Note that there is a small spring that pushes the button upward, you don't want to loose it.
To install, push the red button down until it clicks into place.
How to replace the red seatbelt release button
- Has thanked: 1611 times
- Been thanked: 4074 times
Some of these seatbelts have electrical connections to the SRS in which case be careful you don’t break a connection with the barttery connection.
The dealer tax to reset a SRS is $150
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
This is great! I've been dealing with a hole in my driver seat button for a few months now.
- 2450 Views
Last post by T64me
- 10 Replies
- 2829 Views
Last post by Cookeh
- 510 Views
- 1271 Views
Last post by oizdaman26
- 1199 Views
Last post by Vova585
