2004 XC70 Broken front macpherson strut spring after being towed home.
shiloh51933
Has thanked: 28 times
Been thanked: 17 times
Post by shiloh51933 »
So a month ago a pcv system coolant line split at the clamping location. I had it towed home to repair because it required removal of airbox, MAF to Turbo tube, upper engine torque mount, upper strut brace. Somehow this broke the F/R Macpherson strut spring, dont ask me how and I'd like to add that springs were replaced when I replaced shocks, strut mounts, spring seats and hardware 2 years ago. I purchased from FCPEURO.COM so there warranted for life but damn. I've attached pics...even after removing piston nut and cross nut I couldn't remove spring from strut because the spring somehow wrapped itself around lower portion of strut piston body. I had to cut spring off in pieces.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Sad to see. I feel the springs for XC70 are somehow fragile, even the original ones. What was the brand for this replacement? Is that the 'quick struts' ?
Been thanked: 504 times
Post by cn90 »
- How many miles?
- Maybe that spring is rusted and was about to go south anyway, I don't think the shop did it. It is NOT easy to break a spring.
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
Springs break. They are mainly designed to go up and down. As I understand it the metal is manufactured to be happy stressing up and down, but this is at the expense of other directions.
A tow truck would be putting pressure on the spring front to back and under weight (up and down) - this is a perfect condition for them to fail. Sometimes a good pot hole causes the same stress if the impact is just right.
Unfortunate, but not unheard of.
mrbrian200
Has thanked: 7 times
Been thanked: 84 times
Post by mrbrian200 »
I don't quite understand how the lateral force presented to the coil spring by a tow truck would be different than the same stresses that you would see normally through stomping on the gas or braking hard. The tow truck grabs onto the wheel, not the spring.
I'm thinking that would have broke soon with or without the tow. Probably defective/lacking in some way.
Like with windscreens, I could easily see coil springs from a supplier listed as OE purchased here may not come from the same factory or be the same quality as what was originally installed during original vehicle assembly in Europe.
Rattnalle
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
The parts bought from Volvo dealers in Sweden are probably different as well since it's been so long since the cars were new. Add an ocean in between and some local sourcing to that..
Has thanked: 1609 times
Been thanked: 4065 times
They probably caught a strap or chain in the spring when they locked it up. Not really something one can prove.
shiloh51933
cn90 wrote: 08 Nov 2018, 18:58 - How many miles?
They were factory springs that I purchased from fcp not even 2 years ago. I bought new Sachs struts, strut mounts and everything else all factory or better. The driver side broke not even a year after replacement. It was towed, not worked on by a shop.
shiloh51933
abscate wrote: 09 Nov 2018, 05:17 They probably caught a strap or chain in the spring when they locked it up. Not really something one can prove.
Yes sir!! They used straps because the P2 doesn't have frame towing hooks. P2 has crappy eye hooks that screw into the bumpers.
shiloh51933
mrbrian200 wrote: 09 Nov 2018, 00:40 I don't quite understand how the lateral force presented to the coil spring by a tow truck would be different than the same stresses that you would see normally through stomping on the gas or braking hard. The tow truck grabs onto the wheel, not the spring.
I'm sorry it was flatbedded because its AWD, problem is the P2 chassis doesn't have towing hooks to pull onto flatbed tow truck. So they used straps and probably wrapped around control arms. A pneumatic flatbed goes into a steep incline when loading/unloading vehicles...I was thinking that a strap holding onto control arms instead of frame hook would cause spring to pop loose or break.
