2006 S60 Thermostat Replacement - Is housing replacement req
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Re: 2006 S60 Thermostat Replacement - Is housing replacement req
Post by MadeInJapan »
Oh, and cn90- thank you for your excellent write-up!!
DanaT
Year and Model: 2004 s60 awd
Post by DanaT »
OEMVolvoParts wrote: 05 Jan 2010, 08:51 For your 2006 2.5T it is required that you change the entire thermostat housing when replacing the thermostat. It is only offered as a whole unit from Volvo. You might be able to get it off and apart from the car, but once you do, there is no way to get the thermostat by itself. It is only offered WITH the whole housing. Part number is 30777476 for housing (includes t-stat) and 8636573 is for the gasket.
FYI - The only time you can change the t-stat by itself on S60/V70 cars is -2001 for the turbos and -2002 for the non-turbos. Otherwise it is required you change the whole t-stat housing.
I have. 2004 s60 heater not blowing warm. Told it needs new thermostat as water temp only 120'. I just had the whole housing and thermostat replace just over two yeas ago (little over 10,000 mi). Why would this need replacement so soon? Why does the entire housing have to be replaced again?
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Hi there, try first this easy test to see if the stat would be stuck open www.youtube.com/watch?v=gQxQnuU22Ow
An inexpensive brand may fail in a short time.
Secondly, when you say water temp 120F, is that measured with a code reader or at the vents? If it's a real coolant temperature measure, then it is very low. I would even say it's a temperature for a car that had its thermostat removed all together. Does the temp needle on the dash climb steadily and stay near the 12 o'clock mark? Does it move down as you drive the car at speed?
Been thanked: 471 times
Post by cn90 »
DanaT,
- Use Wahler, but see my DIY, you can swap only the thermostat and ECT.
- Your heater core is probably bad. Use only Volvo or Behr (about $100 at FCPEuro), very easy DIY.
DanaT
Post by DanaT »
oragex wrote: 23 Nov 2018, 17:12 Hi there, try first this easy test to see if the stat would be stuck open www.youtube.com/watch?v=gQxQnuU22Ow
The temp guage reads normal/middle. Mechanic did the temp assessment, not sure how. He believes the guage is not reading correctly.
We've had a perpetual coolant leak requiring filling the overflow tank every week. Pressure test holds. No visible leaks, no smells, no fogging inside.
DanaT
Post by DanaT »
cn90 wrote: 23 Nov 2018, 22:30 DanaT,
Do you have a link for your video?
Post by cn90 »
DnaT,
I already posted the info earlier in this thread (on the 2nd page!). Anyway, will repost the same info again.
- Wahler is now about $95.
- Go to FCPEuro and enter 31293698 and buy the Wahler brand. FCPEuro has LT warranty:
https://www.fcpeuro.com/products/volvo- ... 0-31293698
- No need to replace the lower part of the housing. Just swap the Tstat itself, ECT, upper housing and the new gasket over and you are done.
- If you take your time and read the thread below carefully, then it is a 30-min job max!
DIY: 2005 Volvo XC90 Thermostat + ECT without removing PS Pump
viewtopic.php?t=79031
oragex
Post by oragex »
Do you see white marks around the top of the coolant reservoir? That would explain a leak at the small return hose or at the reservoir cap.
How many miles on the engine ? Was the water pump already replaced?
Post by cn90 »
Over the years, I have noticed Volvo changed the PN for the thermostat for the different yrs of P2 S60 cars, which I don't quite understand why.
Anyway, I have swapped early type tstat and later tstat without issues.
In other words, I have used thermostat "designed for 2004 S60" in a 2007 S60 w/o issues.
Why do I say this? Sometimes ebay has sellers who try to get rid of their Volvo Genuine thermostat (brand-new old stock = NOS) for let's say $50 instead of the usual outrageous price of $110. I bought a brand-new Volvo thermostat for 2004 and installed it in a 2007 w/o issues.
For example:
- 2004 S60 2.5T 31293700, nipple = 33mm long vs 2007 S60 2.5T 31293698, nipple = 25 mm long.
- The only difference is the length of the nipple (for the coolant hose in the PCV system).
Has thanked: 1505 times
Been thanked: 3817 times
cn90 wrote: 27 Mar 2022, 15:47 Over the years, I have noticed Volvo changed the PN for the thermostat for the different yrs of P2 S60 cars, which I don't quite understand why.
For example:
Great info on the part numbers and compatability. Added part numbers to title
